Question about Gateway GT4016 Desktop PC
My disc drive wont open, i tryed hitting it, prying, and even tearing off the front off my tower! any ideas?
    Problem Solver:
  • 13 Answers
Try using a pin or paperclip in the small hole located on the front of the disc drive to manually open.
Posted on Nov 14, 2009
  • Gateway Master
  • 13,433 Answers
In windows, go to my computer, right click on the cd/dvd drive and select eject, does that work? if it doesn't. then you would have to take the computer apart - void the warranty most likely.
Open the side panel of the computer, possibly remove the plastic front cover. make sure the wires are connected to the drive properly, power and IDE or SATA cable. Then in the front, you should have a small hole that you can use a paper clip to push in and manually eject the drive.
if the drive still doesn't eject, buy a new drive from www.newegg.com for example - get a DVD burner, (20-30usd $) unscrew the old one and remove it, put the new one on its place and so on.
Make sure if you buy a new drive that its the same type, if your drive has a 4 pin power cable (yellow, black, red wires) and a 40 pin / wire wide cable then its a IDE drive, buy a IDE dvd burner.
if your drive has a 4-5 pin power cable and a flat small wire like mostly red, then you have a SATA drive, buy a SATA dvd burner.
If you need futher assistance, let me know.
Thanks,
Ekse
  • Cobriac Aug 17, 2012
    THANK YOU THIS OPENED IT BUT IT WILL NOT OPEN ON ITS ON DO I NEED TO REPLACE THE DRIVE OR IS THIS A CPU MALFUNCTION? THANK YOU FOR ANY ANSWERS
  • 553 Answers
In front of your cd rom disc drive you will see a very small hole, try to insert a small sharp object or pin that will fit in the hole, that is the bypass key to open the disk tray
Why wont my cd drive work
see this and fix it. God bless you
Turn on your computer and open the CD drive by pressing a small button on the front of the drive. Use a can of compressed air to clean the lens by spraying a few squirts of the air into the drive. This will fix disc skipping if there was dust on the lens.
  • 2 Place a CD drive cleaner into the disc drive. This is a disc that is specifically designed to clean CD drives. Allow it to run for a few minutes, and then extract the disc from the optical drive.
  • 3 Click the "Start" button and then click on the "All Programs" option. Click on the "Windows Update" icon and then click the "Check for Updates" button on the left side of the screen. Click the "Install Updates" button at the bottom of the screen to update the drivers for your CD drive. Restart your computer for the driver changes to take effect.
  • 4 Unplug the power cable from your computer and use a screwdriver to open the tower door. Locate the CD drive cables inside the computer. Make sure that the CD drive cables have not loosened. If the cables are loose, then the drive will not operate properly.
  • Sep 27, 2012 | Acer Computers & Internet
    I need to get a dvd out of the tray
    Don't! first of all make sure that the dvd didn't tear into pieces, if teared then nothing to do, buy a new DVD Drive, if not you would notice a little hole in the front of it, try with a pin into that hole and push it, the tray have to come out, then everything will have to work as normal.
    Jan 10, 2012 | HEWLETT-PACKARD Pavilion Slimline s5510f...
    My games wont play and it says open tray
    You have dirty laser or bad laser or dirty disc drive period. Try cleaning laser with qtip. If that doesnt work keep the disc drive apart and hook it up to the 360 make sure not to let your disc drive ground out anywhere on the 360. Hit eject button and close tray seeing if the laser even goes up with the tray. If it doesnt try greasing the rails and gears in there where everything slides.
    Nov 20, 2010 | Microsoft Xbox 360 Console
    CD in stuck in the computer and I can't get it out using the eject button. How do I get it to come out?
    hi,
    its too simple. you dont need to worry.. Check the front side of the CD ROM. you will find there one small hole. Now just take a thing, which is around the 4 to 6 inch (min is 4") long and can pass through that hole (for eg. take medium size U pin, and remove all bends and make it straight or long needle) Now insert this equipment in that hole and press. your ROM will eject...
    Hope this has helped you ... Thanks....
    Jul 19, 2010 | Computers & Internet
    Disc Tray will not open
    My Gateway model #AR-230 tray would not open after several years of use. Removed the black sheet metal cover from the player to access the tray mounting screws in the black plastic tray frame. By tightening or loosening the little screws on both sides of the front of the tray mechanism, I got the tray to slide out (open) reliably again. The problem is the very close tolerance of the internal tray mechanism with the front case opening causes a mechanical hangup or interference. chemicalladdie
    Sep 14, 2009 | Gateway AR-230 DVD Recorder
    PS3 Won't Take Disc!
    Hi, I think it was me who had helped you before. I will be glad to help again. Ok, first you have to tear apart your PS3 (just like when you cleaned it). Now looking at the rollers and "dogs" make sure that they are closed and not open all the way like when a disc is in it. Look at the flap on the top too make sure it opens and closes freely. Next, PLEASE BE CAREFUL!! Plug your PS3 in and try to hit the eject button, if it is reset and ready for a disc it will beep twice when you hit the eject button without a disc in it. Place the top back on the he DVD drive and try to insert a disc. At this point it should take it. If not then try hitting the eject again. Once the PS3 resets and takes and ejects discs again, then you can put it back together.
    Aug 13, 2009 | Sony Playstation 3 (PS3) Console
    Xbox wont read discs, unless i hit it....
    open tray right??
    -check the time and date settings,even the time zone as well
    -try to load the disc without the hard drive or memory unit
    -look for corrupted files at the memory, delete it
    -do the system maintainance,
    system settings>>memory>>hardrive, press y for device options, press this in sequence x, x, Lb, Rb, x,x>>yes
    Jun 27, 2009 | Microsoft Xbox 360 Console
    Tower disc drive won't open
    What bunnydawg means is it connected properly to the psu. If lights flash it could simply be jammed If they dont open up the back and check the plug with four metal points in it is in properly
    Sep 07, 2008 | Acer Aspire™ T180 PC Desktop
    DVD tray wont close
    Hi , reset the computer try to open dvd and okey if not try to check belt it visible near the cd tray if still align with the pulley.
    Jan 31, 2008 | Bose 3·2·1 II System
    Disc drive
    Ouch. Try turning the unit 90 degrees (upright or flat, whatever's different) and hitting the eject button again.
    Does the unit turn on okay? Is there a disc in the drive or is it empty?
    If nothing else works you might be able to gently pry open the drive with the power off on the console. I suggest using a paper clip or very small screwdriver. Take it slow and try to pry it straight outwards.
    Dec 18, 2007 | Microsoft Xbox 360 Console
    Gateway GT4016 Desktop PC Logo
    208 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
