Question about Canon PIXMA MP620 All-In-One InkJet Printer
Mp620 Error 5100 on canon is a Carriage Home Position Error printer printer was dropped
Hello i had the same problem with my canon pixma ip 3000 and i found this steps to reset the printer and it work i hope it will help you in yours.
Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
here is the link for other printers: http://www.cyber-ink.com/member-canon.html
Solution posted on http://www.fixyourownprinter.com/forums/laser/25975 by sguadalajara. My mp620 was printing fine at 600dpi but a 5100 error used to came up when i was trying higher resolutions. I followed the instructions above an the error disappeared. :)
Posted on Nov 30, 2009
  • 3 Answers
Also i just got one from a thrift store and found that there is a spring catch that holds the carriage up in the rest position and the spring had sprung and was not holding the carriage up and the ink jets got messed up and spewed ink all over the place lol took me 3 hours to clean the gunk to then find the spring problem..... to check this open the cover where the ink is. After the cartridges go to the change out spot on the left then carefully reach in with needle noise pliers and push in and lift up on the purge it should raise then when you ease it back it should lock into place and then there is a spring lever as your looking into the printer closest to you in front of the purge if you pull back gently and the purge does not move downwards then that is your problem its a pain in the @#$ to reset, the bottom of the lodges in front of the lower arm assembly of the catch, the top of the spring it goes forward towards the purge and is wedged underneath a small platform with a small notch about 1/16"x 1/32" but after i did this no more error 5100 now i just need new ink cartridges : D
Posted on Feb 24, 2013
I Have a a Canon PIXMA MP810, suddenly showing error code 5100 How can I fix this? Gene Deitch genedeitch@yahoo.com
Hi
Error 5100 on canon is a Carriage Home Position Error. Try reseating the printer cartridges. If that doesn't help make sure there is no paper stopping the carriage from moving right to left. Try cleaning the plastic strip (encoder strip, behind the carriage) that runs the length of the carriage, it may be contaminated. Use alcohol and a swab (Q-tip) to clean. Before cleaning unplug it from the power supply. Hope this helps...please post back for further assistance.
Daniel
Jan 08, 2011 | Canon Office Equipment & Supplies
Printer is an iP90 and the error code showing when I try to print is "5100"
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
Aug 28, 2008 | Canon Office Equipment & Supplies
What is error code 5100
5100 is a Carriage Home Position Error. try cleaning the plastic strip that runs the length of the carriage, it may be contaminated. Use alcohol and a swab Good luck. Thanks for using FixYa.
Jun 09, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Getting a 5100 error message on our MP620. We reboot the machine and it functions fine for multiple print jobs then errors again.
5100 says the carriage is not moving freely across the page or there is ink or grease on the encoder strip. Look inside for any paper scraps, and clean the strip that runs across behind the carriage assembly with a Q-tip damp with alcohol. It's fragile, so don't press too hard.
Feb 01, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Error 5100
Hi
Thanks for using FixYa. Error 5100 on canon is a Carriage Home Position Error. Try reseating the printer cartridges. If that doesn't help make sure there is no paper stopping the carriage from moving right to left. Try cleaning the plastic strip(encoder strip, behind the carriage) that runs the length of the carriage, it may be contaminated. Use alcohol and a swab (Q-tip) to clean. Before cleaning unplug it from the power supply.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Canon PIXMA MP620 All-In-One InkJet...
My Pixma ip1980 service error 5100
Aug 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How to fix error 5100.
Jun 29, 2009 | Canon i80 InkJet Printer
Error 5100
Jun 29, 2009 | Canon MX300 Office All-In-One Printer
Error 5100 for PIXMA PM 180
Oct 07, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Error 5100
see if that helps
Robert
Please rate this solution thanks
Aug 26, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MP620 All-In-One InkJet Printer Logo
2,988 people viewed this question
old marine
old marine
