Aurora shredder Mod # AS1019CS gears replacement instruction are needed. I have removed all five screws on the bottom side but the housing is still not coming appart. Something in the middle is catching even after I have a 1/4'' gap all around.
  • 610 Answers
May be a screw hidden under a sticker on the bottom, but I don't think they make replacement parts.
Posted on Nov 15, 2009
  • 42 Answers
Call Aurora customer service at 1-800-327-8508 in the USA
International only 14-310-793-5650
it cost me $15.00 for the two gear parts for my shredder model AS1019CS including parts, tax shipping and handling
Posted on Jul 25, 2011
Lol! Under the tag that says "warranty is voided if removed" there is another screw, right in the middle
Posted on Oct 07, 2010
It is an extra screw under the sticker for sure
Posted on Jan 15, 2010
Aurora as1010cd paper shredder im having trouble removing the top
I would advise you to reconsider why you want to remove the top.
Oct 31, 2016 | Shredder Office Equipment & Supplies
Aurora shredder model as1019cs has jam
Run it in reverse for about a minute. If you have tried that, get a pair of needle nose pliers and clean out all shredding from the cutters. If you are handy, unscrew the bottom of the case from the top to access the cutting wheels, Use the needle nose pliers to remove all impacted shredding.
Oct 08, 2014 | Office Equipment & Supplies
Aurora paper shredder model AU1050XA
Stan Chandler:
First, unplug the shredder. Remove the shredder head from the basket and turn it upside down. You will see the screws on the bottom side of the shredder head.
Feb 23, 2013 | Aurora Electronics Office Equipment &...
My schreader was working and just stopped schreaeding . It is not jammed . Do you know what might cause this . How can I fix it ?
There is a very small micro switch on the bottom left hand corner of the unit. This switch needs to sit securely on a mall shelf protrusion that comes out of the base. If the switch isn't properly pressed the unit will not operate. If you search the bottom corners you'll see the tiny switch. If you press it the shredder will begin to work again. You just have to reseat the unit into it's original base and the little shelf will press it for you.
Jul 18, 2011 | Aurora Global AS501X-MS Shredder
I need a new plastic drive gear where can i get one and cost
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. I paid $15.00 but my model number is AS1019CS for the part, with shipping and handling. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Apr 24, 2011 | Aurora Electronics AS1200X Shredder
It will come on but when i put the paper there to shred it, it wont do anything.
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Apr 22, 2011 | Aurora Electronics AS-650C Cross-cut...
One of the gears in my sb-97cs has broken. The motor runs but the broken gear prevents the teeth from rotating and pulling paper into shred. I have spoken with people at Fellowes on the phone and they have...
I have the same problem with a stripped gear, to remove the top i found it best to place the shredder on its back, then with a pozi screw driver there are 5 screws securing the top in place, these are inside the shredder above the paper bin, 1 in each corner and 1 in the centre.
Hope this helps.
Jan 14, 2010 | Fellowes Manufacturing Powershred SB-97CS...
Need nylon gears for 57c.where can i get them?
Heres a few sites that have gears another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
To take apart ,UNPLUG the unit
There are 7 to 9 screws on the back depending on which unit
gently pry the two halves apart .if it seems stuck you may have missed a screw or
The blades are held by a plate on one side and this is fit snug to the top and bottom halfs , use a screw driver or butter knife to get it started then pull firmly upward with both hands , flip the top over and be gentle with the wires as they will remain connected.
pull out the motor and gear housing , remove the black plastic retaining clips from the gear housing then remove the 5-7 screws in the white gear housing , the one half (cover)will come off exposing the gears and you can identify wich gear is broken and replace it .
this is a good time to clean it out too :)
Jul 12, 2009 | Fellowes 3011001 Shredder
How to disassemble Fellowes P70CM Shredder
Agreed, there is a seventh screw under the label, as wstrooper suggests. Press along the label and you'll find the tell-tale indentation!
Having taken it apart (a further 4 screws to remove the nylon housing from the base, and another seven to remove the nylon covering for the gears), it has revealas a stripped gear (the one nearest the motor), caused by too many sheets of paper being fed in.
This problem seems to repeat amongst several P70CM owners. Shame the motor doesn't have a cut-out if it hits too great a resistance, rather than strip the gear of its teeth.
Jul 27, 2008 | Fellowes P70CM Shredder
Runs in reverse only
sometimes there will be screws hidden under stickers or plugs
Oct 24, 2007 | Cross AS1512X Shredder
867 people viewed this question
jasbo
jasbo
