Question about Cadence Cat Eye Strada Computer
Accuracy I've only had my strada long enough to put a couple of hundred miles on it - but I can't seem to get he wheel size to give me accuracy on the trip odometer. What gives?
    Problem Solver:
  • 17 Answers
Um take it to bike shop there had to work ay um or just play around with it and look at instructions
Posted on Nov 15, 2009
27000km best fuel usage 11.4 L/100 no joy from Mazda Aust. Put 285/70 17 tyres 14.3L/100
Putting different tyres on will alter the accuracy of the speedo and the recording of distance, so I wouldn't pay much attention the fuel economy. For example, a single revolution of the axle will remain constant regardless of the wheel size, but the revolution of the wheel versus distance traveled will vary depending on the diameter of the tyre fitted. If the new tyre was, say 10 cms circumference larger, then the car will travel 10cms further each full revolution (that is 100 meters every 1000 turns. If your speedo sensor is determined by the number of revolutions of the axle, then every 10,000 turns you will have travelled a kilometer more than with the old tyre size (less if the circumference is smaller). The figures you give convert to (UK) 25 mpg dropping to 20 mpg with the new tyres. Does seem poor consumption figures for a small car, but if a big engined truck that might be acceptable. All depends on how you drive it as well.
Feb 08, 2016 | Mazda Cars & Trucks
Winding out in 3rd gear
a good trans filter and fluid change might help
Sep 23, 2012 | 2005 Isuzu Ascender
1995 Toyota Camry Harmonic Balance
A little risky. If it comes apart on the trip you will need a tow. Yes, the harmonic balancer does occasionally break, and require replacement. It shouldn't take a shop very long to replace it. Just the belt is removed, the crankshaft pullley bolt is removed, and the old pulley pulled off, and a new one put on. I wouldn't chance it for 700 miles, but...it's up to you. Good luck.
Jul 12, 2012 | 1995 Toyota Camry
What number do I put in for wheel size 700x23 on a blackburn atom 4 cycle computer
You don't want to guess. Every tire varies from the nominal size to some extent. Measure one wheel revolution on the ground in millimeters and use that number. With 4-digit accuracy it seems silly to ballpark the measurement.
Apr 04, 2011 | Blackburn 4.0 Bike Computer
I put in a new battery. I went to get it inspected and it failed. The inspector said I needed to drive it about a hundred miles before the computer will reset. Then bring it back and have it inspected...
Once disconnected from the battery the computer needs to go through a drive cycle during which it does internal testing of the sensors. Generally that only takes a trip of about twenty or so miles. The inspector probably told you one hundred just to be on the safe side. Most times, you don't need to make the trip all at once but over the period of about a week, driving normally, with a few longer trips mixed in, everything should re-set.
Feb 15, 2011 | 2001 Jeep Grand Cherokee
Humminbird 798 has erratic gps speed readouts at slow speeds between 1 and 3 miles per hour. Speeds bounce up and down between 0.1 and 3.0 mph even when sitting in the boat in my driveway!
I had the same problem. I talked to 3 different technicians on the Humminbird support line about it. All 3 of them confirmed that this is how their technology works. They ping the GPS satellites continuously, and at low speeds the GPS accuracy causes the speed measurement to fluctuate wildly. It smooths right out when you go faster than 3 MPH, since your boat moves far enough at that speed that the GPS accuracy is no longer a problem.
Seems like they could easily overcome this issue by averaging GPS readings over a longer time period at low speed (i.e. give the boat enough time to move far enough to eliminate the accuracy issues), but they don't do that.
It was a big issue for me since I do a lot of trolling at low speed and need an accurate speed indicator, so I returned the product and bought a Lowrance instead. Lowrance doesn't have this issue.
Oct 13, 2010 | Humminbird 798ci SI Combo GPS Receiver
Hurt front end
not trying to be rude but do be sure the wheel is tight. a build up of corrosion on the wheel or hub could cause the wheel not to set n lug studs correctly. that would cause a knock noise and will shake the wheel
Nov 17, 2008 | 1995 Jeep Grand Cherokee
Fork seals
ZERO air pressure on these forks those air valves are to get rid of any built up pressure in the tubes. I also have a 1990 851 love it! What weight of oil are you running and how much are you putting in?,,
Nov 10, 2008 | 1988 Ducati 851 Strada (Tricolore)
Steering wheel controls
i have the same problem. Still looking for the solution
Jan 29, 2008 | Panasonic Strada CN-NVD905U GPS Receiver
Cadence Cat Eye Strada  Computer Logo
138 people viewed this question
Top Cadence Cycling Experts
John Egan
John Egan
Are you a Cadence Cycling Expert? Answer questions, earn points and help others
