Question about Solis Master 5000 Espresso Machine
Machine Grinds, but not water comes through. Coffee stays dry.
  • 1,089 Answers
Hi
Remove the brew unit. Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door (looks like a long "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers.....
Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
Posted on Nov 14, 2009
Machine leaking water
What type of machine would help
Oct 24, 2017 | Coffee Makers & Espresso Machines
Saeco incanto Sirius
try to make preground coffee without powder. If the water don't come out -may be you have to change the pump.
Nov 23, 2013 | Saeco Coffee Makers & Espresso Machines
I am getting no coffee to dispense out of the coffee output. It gives me no error message. It grinds the coffee and acts like it is dispensing the coffee. But nothing comes out. My coffee grounds...
firs of all try to make preground coffee ,but without coffee powder if the water come out then you have to change the pump. If no water come out -your machine needs to be descaling
Oct 18, 2013 | Saeco Royal Professional Espresso Machine
Machine has a water circuit problem. The machine grinds the coffee but nothing comes out and there are dry coffee grinds in the tray
Check the bgrew group screen to see if they are clean and clear also under the top screen theres a small hole make sure that is clear also? Has the brew group ever been degreased this is if there is water coming out of the wand if no water there you have a internal blockage or pump problem
Dec 17, 2009 | Saeco INCANTO DELUXE Espresso Machine
The Saeco Incanto machine grinds away but no water or coffee
Are there any grounds in discharge tray and if yes are they wet or dry?
If they are dry then the machine has a water circuit problem. If they are wet then the brew unit is blocked or the grind settings need to be adjusted coarser.
Jun 29, 2009 | Saeco INCANTO DELUXE Espresso Machine
The water is not adding to the ground beans , is it plugged?
I haven't seen a Vienna in a long time so I cannot remember if there is a door for preground coffee, if that option is there, open door and press button to make a coffee if you get water, then adjust the grind and dosage on the grinder and try the auto function.
Jan 17, 2009 | Saeco Vienna Digital Coffee Maker,...
Water does not get to main compartment
try priming the machine ( find the plastic gizmo that came with the machine for this purprose..can you get water from the steam nozzle?..there is an internal water filter that may become clogged if you aren't keeping the water tank clean.
Dec 14, 2007 | Saeco Vienna SuperAutomatica Coffee...
Solis Master 5000 Espresso Machine Logo
402 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
