Question about Car Audio & Video
HELP hello heres the problem i have an mtx thunder 4250d amp and a jbl gt5-12 subwoofer. everything is connected properly, i have had it checked by a couple of mates and they said the wirinig is fine. when i connect the sub it does vibrate although not enough to actually make me believe it is working... what do i do? thanks
  • cmccullough Nov 14, 2009
    yea the amp has been adjusted and i think the jbl sub is decent enough. everytime i connect the sub it looks like it is going to blow dont no what else to do.
  • 1,165 Answers
Have you adjusted your settings on amp.is sub actually good .
Posted on Nov 14, 2009
How big of hole do i need for the mtx 6000 thunder 10in
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
Mar 01, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
What kind of amp should i get for my kenwood mids and highs
you should go for a 4 channel amp that has 500 watts and try to go for MTX
Aug 04, 2010 | MTX Thunder 4250D Car Audio Amplifier
What kind of sub would go good with my amp the MTX 4105 d amp
you can try the new soundstream T5 or a MTX 9500 but the T5 would sound deeper and cleaner
How can i hook up a second battery to my MTX 4105d amp
well the best way is keep the amp hooked up how it is now and on your amp there is a + and a - for a cap hook up the negative to the negative for the battery and the positive to a fuse like with a 60 amp fuse then the other end of the fuse link goes to the battery
I have a MTX 4105D amp and it cuts in and out what could it be
could be not enough voltage or the settings on the amp are not correct for the sub you have its a feature that MTX put on thier new amps
I need 2 chips for an mtx roadthunder 4250d amp the number on the chips are 75339p then there is a y1 and a 44 if u could tell me were i can get them it would be apreciated both chips are the same
HUF75339P3-ND
THE ABOVE LINK WILL TAKE YOU TO THE DIGIKEY PAGE THAT HAS YOUR MOSFETS YOU ARE LOOKING FOR IN THIS AMPLIFIER. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Oct 27, 2009 | MTX Thunder 4250D Car Audio Amplifier
I have one mtx t4510-04..what amp do you
Hello jandytaala,
The recommended power range for you T4510-04 is 112.5 to 225 watts RMS. So you need a monoblock amp within that range. You could go up to about 300 watts RMS, but watch the gain and don't try to get too much from a single 10" sub.
The Orion Cobalt shown here would be a good match and is only $139.99. For another $60, the Alpine MRP-M500 will output 300 watts into 4 ohms.
Hope this helps.
Aug 28, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
MXT amp 4250D they replace the 2 IRFB42N20D the 3 R220 with 3 resistor It work a little bit then the sound get distored
who ever did the repair missed something to replace and or the "Metal Oxide Semicondutor Field Effect Transistors" ic's went bad again
Apr 03, 2009 | MTX Thunder 4250D Car Audio Amplifier
My subwoofer doesnt work
you mean that the SUBWOOFERS connected to the amp cuts off and come back on randomly?? did you bring the SUBS level to a high volume ? i suggest to check first the value of the speaker (ex. 4 , 8 , 16 ohms ) matches the same value with the amp . second , hows the subs connected , in series ? or parallel . you will need a multimeter for this task .
Apr 22, 2008 | MTX Thunder 8000 T8154A Car Subwoofer
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
