Question about Frigidaire GLER341A Electric Dryer
Dryer will not start!
Have changed all the fuses in the house and have checked the connection and things are fine there and have had thermal limiter replaced but it still will not start! Dryer wasn't even a year old yet when I started trying to fix it, know of anything that I might have missed!
  • kcweller Jan 09, 2008
    it's not a door switch this is what the manual says and what I have done all ready!but it still does not work!
    OCCURRENCE
    Dryer does not start.
    POSSIBLE CAUSE
    Electrical power cord is not securely plugged
    in or plug may be loose.
    House fuse blown or circuit breaker tripped.
    Thermal limiter tripped.
    SOLUTION
    Make sure the plug fits tightly in wall outlet.
    Reset circuit breaker or replace fuse.
    Make sure electrical line is not overloaded and the dryer is on
    a separate circuit.
    Call authorized service person for replacement
    my husband changed out the thermal limiter! I checked the rest of this and it still does not start!
    this is the part and number on that and it's in the cabinet area near the terminal block! and Terminal block heater, housing
    36 # 134120900 Thermal Limiter
  • Bill Aug 30, 2008
    I have the same problem and replaced the thermo limiter. The dryer worked for a few loads and then stopped again. Waiting for a replacement thermo limiter, I bypassed it (taped the wires from the thermo limiter together) and the dryer works again. I believe the new part suffered from infant mortality. Having bypassed the thermo limiter, I am careful and monitor the dryer temperature.
    I was told the thermo limiter may trip if the vent line is plugged, so I need to be careful and monitor the temperatures while the part is bypassed.
    Sergeant:
    Champion:
  • 262 Answers
Door switch limited information tell me more
Posted on Jan 08, 2008
  • Bill Dozier Jan 10, 2008
    looks like you have covered everything only thing left is the timer and the start switch on the motor and on the console look at your wiring diagram that is in the console and check voltage on these items also look for hidden fuses there should not be any but look any ways let me know what you find or need any more help good luck
Admiral dryer ADE 7000 AYW will not start. Timer will work, but that is all. I think it could be the limit switch, but am not sure. Then was told it could be the thermo fuse. Could you please offer...
It very likely is going to be the thermal fuse that is a very common failure when the dryer will not start. To open it up to check the thermal fuse,the top pops up..to pop up the top use a putty knife and place it between the top and the top of the front panel at the corners and depress a clip on each corner that holds the top to the front panel.
Once the top is up the thermal fuse can be found on the right side of the housing where the heat element goes...that housing where the element is mouted to the rear of the plate that supports the rear of the drum at the top,the thermal fuse will be on the right side of the heater housing about 3-4 inches down on that housing..if memory serves me their is 2 white wires connected to the thermal fuse and to check it disconnect those wires and check the thermal fuse for continuity with zero ohms resistiance...if it has a open circuit its will be bad
The part number for that thermal fuse is LA-1053 it also comes with the high limit t-stat which you will see on top of the heat element and it to should be replaced when replacing the thermal fuse
GENE
Sep 24, 2011 | Dryers
Kemnore 80 electric dryer: dryer spins, light works, heat does not work...used multitester on ohm setting to test for continuity on coil and thermal fuse...both seemed to be fine...back to square zero
In addation to testing the element and thermalfuse what ya need to check is both of the thermostats that are on left side of teh housing where the heat element fits into,both of those should have zero ohms resistiance,also should check the cycling t-stat there where the thermal fuse (in the blower housing) be sure to not confuse the thermal fuse which is the blower housing with the thermal cutoff which is on the heater housing that and the high limit t-stat are the ones in the heater housing and are the most likely things making the dryer not heat.
If all above checks to be good, the timer, or the motor is whats wrong causing it to not heat.
GENE
Sep 20, 2011 | Kenmore 63942 Dryer
My kenmore dyer about 16 yrs old died on me in mid dry. It will not start now. I checked circut breaker in home was fine. I checked continuity in push to start switch,Hi limit thermostat, 250 degree therm,...
Hello there and thank you for choosing fixya
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block that it is attached too
Jul 31, 2011 | Roper REX4634KQ Electric Dryer
DRYER STOPPED RUNNING. ALL CONTROLS WORK, BUT WON'T START. HIGH LIMIT SWITCH GONE?
It's either of the thermal fuse on the blower housing or the thermal fuse on the heater enclosure is blown. These thermal fuses are wired in series with the motor and therefore, if any of them is blown will cause the motor not to run and hence the dryer not to work except the controls.
Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
Bypass the thermal fuse on the blower housing by disconnecting the wires and taping them together or connecting a jumper wire between them. Close the door then plug and start the dryer.
The dryer should start and heat up if the blower housing thermal fuse is the culprit. Otherwise, the other thermal fuse on the heater enclosure is blown. Unplug the dryer then bypass the thermal fuse on the heater enclosure in the same way the first is bypassed to confirm it.
Plug the dryer back then restart it. The dryer should start to confirm that the heater enclosure thermal fuse is blown. Replace the thermal fuse (part number 307473) together with the high-limit thermostat (part number 303396).
Unplug the dryer and unbypass the blower housing thermal fuse then plug it back and restart it. If the dryer fails to restart, replace also the blower housing thermal fuse (part number 33001762) together with the cycling thermostat.
Reinstall the front panel in reverse steps of the removal steps to complete the repair.
Aug 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
KENMORE GAS DRYER NOT HEATING UP
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Apr 17, 2010 | Zanussi TC180W Electric Portable Dryer
Dryer won't heat
Hi
Thanks
Rylee
Apr 02, 2010 | LG DLG2532 Gas Dryer
My dryer will not start. i tried a new start switch, no change. the door switch is working. if the thermal fuse is shot will that stop the dryer from working or only stop the heater from working. the moter...
there is 2 thermal fuses on some models 1 for the heater and the other will keep the unit from coming on at all which is most likely your problem. Example on a series 90 kenmore there is a thermal fuse and high limit mounted right on the side of the heater element housing and another fuse and thermostat mounted on the blower housing. The fuse on the blower housing will kill dryer completely.
Jan 08, 2010 | Whirlpool Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Fuse
one fuse is on the heater housing the other is on the blower housing if you have not removed it the wiring diagram is inside the console
Apr 10, 2008 | Kenmore Elite HE4 Electric Dryer
Won't start. The start light flashes. Timer appears to be functioning.
You could have a couple of things going on that may cause your symptoms. First of all, unplug the dryer. If you can access the inside of the dryer check to see if the dryer belt is broken. On some dryer models if the dryer belt breaks a "broken belt relay" on the idler pulley near the motor will trip causing the motor to shut down. This is to prevent a broken belt from becoming wrapped around the motor shaft. Another possibility is a blown thermal fuse or thermal cut-out. Some dryer models have a thermal fuse mounted on the exhaust vent housing and is white in color. This should read a short. There should be a thermal cut-out mounted on the heating element housing as well. There will be a hi-limit thermostat mounted near it. The thermostat will have a resistance reading (can't remember exactly what it is), and the thermal cut-out should read a short. If the thermal c/o is bad, replace the hi-limit thermostat as well. Now if you have a thermal fuse or thermal cut-out problem, they generally blow for a reason. Check your dryer ducting for proper air flow and make sure its not clogged full of lint. Normally, a thermal problem is associated with your dryer overheating. Good luck and let me know if this helps.
Jun 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Frigidaire GLER341A Electric Dryer Logo
107 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
