I was fixing my Maytag Neptune dryer model no. MDE3000AYW. It had been making a knocking noise and I followed the instructions to repair this problem. I believe I've fixed that problem, HOWEVER, I cannot get the drive belt back on to check it out. In reassembling it, I simply looped the belt around the drum and reassembled the entire dyer with the exception of the front pannel. I've followed the instructions from the maunal which was sent to me, but I still can't figure it out.
  • 986 Answers
Have you loosened you belt adjustment bolt all the way? I have never had a problem. Are you sure you ran the belt properly? You have the manual already. There is not much of anymore info that some one here could give you. i could send you a PDF of my manual but you said you already have it. Sorry not to be of more help. Best of luck.
Posted on Nov 14, 2009
Drum making harsh squeaking sound when maytag dryer model MDE 9606 in use
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 01, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Seven year old maytag neptune electric dryer has a squeak when it is runningand need to know what to fix?
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Aug 03, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My dryer makes a loud sqeeling noise when its drying clothes our maytag neptune is a gas dryer thats about ten years old
heatman101
ghgh
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Squeeky noise in the back of dryer when running?
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 12, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Just brougth used maytag neptune dryer.model MDE3000AYW
If you are connecting a power cord with a 3-wire configuration, you match the corresponding wire colors from the power cord to the wires on the terminal block in the back of the dryer. The correct color-code is as follows:
RED - HOT (120VAC)
BLACK - HOT (120VAC)
WHITE - NEUTRAL (0VAC)*
*There should be a ground strap or ground wire connected to neutral at the terminal block in a 3-wire configuration.
NOTE: If the wires are not color-coded, the outer two wires (Left and Right) are the HOT leads. The center conductor is Neutral.
If you have any questions, you can refer to this link for further explanation:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
This explains the difference in 4-wire and 3-wire configurations. I hope this helps you.
Mar 09, 2010 | Dryers
Maytag neptune dryer making a thumping noise while drum turns, as if there were a tennis shoe in it, but there isn't? Ideas?
heatman101
Jan 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer mdg9700aww dryer barrel making noise like is out of round bent or off balance . any ideas ?
heatman101
45d
Jan 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
- very loud squeaking sound
Hello JewettKann,
Typically, on the Maytag Neptune dryers, it is the felt gasket that is the cause and source of the noise you're hearing.
There is a felt gasket that runs all around the front and rear of the dryer drum and cabinet door edge (on the backside lip). As the dryer ages, this felt wears out and needs to be replaced to prevent the awful screeching sounds you'll experience, once the metal to metal contact becomes constant.
You can view the parts that need replacing at the following link (Item #17B on the drawing) Called a sound damper pad on some models.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MDE4000AZW&productCategoryId=0151200&brandId=3048&brandDescription=MAYTAG&modelName=MAYTAG-LAUNDRY&diagramPageId=00004&componentDescription=DOOR&documentId=M0402169&blt=06
This was a fairly common problem with the Neptune line. You can see for yourself by simply turning the drum with your hand and feeling and listening for the rubbing/grinding noise, along the top of the door opening.
If you can get the complete model number off your dryer, you can select the exact line drawing and parts list at the link below to make sure you're looking at your exact model.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=mde4000&=part+number
I hope you find this Very Helpful and best regards!
Dec 25, 2009 | Maytag Neptune MDE4000 Electric Dryer
Metal on metal sound when the dryer is running
I have the same problem and I'm sure its the belt tensioner pulley
Jun 06, 2009 | Maytag Dryers
Maytag neptune dryer making load noise seems unbalanced
Sounds more like the dryer drum seal is deteriorating.
If the dryer tumbles the belt is intact.
To access the belt.
Open the door.
Remove 4 screws on right and left side of the door opening.
Raise the door on the hinge side and remove it.
Pull the front panel forward and remove it.
From there you can see what to do next.
Mar 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
