Question about Linksys Wireless-G WRT54GS Router (e125894)
Can connect with full signal takes a long time to connect even after i have done factory restore
  • 131 Answers
If dsl setup the modem to log in. if broadband, check timeout and mtu settings. mtu around 1560 is best . Also make sure gateway setting both ways, router / gateway timeout should be always on , not on demand. good luck.
Posted on Nov 14, 2009
Factory restore
First try disconnecting both the router and modem from power for a few minutes. Also turn power off to the computer. Restart all of the components. Wait a few minutes and try. It will take a few minutes to restore the connections.
Next from the computer access the router. 192.168.0.1 or 192.168.1.1. Usually the ID is "admin" no quotes no caps.
Querry the router and valadate the settings. If not successfull try resetting the router to factory by depressing the button located on the rear of the unit.
26241694-pbq4lewq4mzzco310yjoakmr-1-2.png Hope this helps?
Jul 20, 2016 | Computers & Internet
Signal full, sufficient balance but at the time of call there is a message "Error in Connection". I can do also Restore Factory Setting.
Hi
The problem is most likely caused by a weak 3G signal that your handset is picking up. A weak 3G signal can cause odd problems like connection errors and call dropping.
Try disabling 3G to test to see if it's the cause of your problems.
The setting can be found in the network settings menu. It should be set to GSM, not dual mode or UMTS.
Jun 27, 2011 | Nokia 2730 Cell Phone
I use nokia 3110c mobile phone i have my msgs from inbox deleted whenever i restart my phone... i have my music files not found when i try opening the music player.... i have no applications working...
Software complaint... Goto any authorized service center and ask them to re-flash the software..!
It will take only 15 minutes to flash the software... I have done this many times for my customers... It is also very cheap, In India re-flashing the software is done for just $5...
Feb 15, 2011 | Nokia 3110 Cellular Phone
Quite often my Nokia 5800 will lose signal completely even in spots where I usually have a strong signal. Also, sometimes I can't send texts or even phone someone even when my signal bar is full which...
have you tried to restart your phone? if not, kindly try it and if your phone is still the same way you can try restoring it to its factory setting by clicking the menu-->settings-->phone-->phone management-->factory settings and select yes or try to master reset your mobile by just dial *#7370# and accept but before that i suggest that you should back up your file first.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 25, 2011 | Nokia 5800 XpressMusic Smartphone
My tomtom300 turns on but wont get signal
try to restore or reset to factory settings in the menu
Nov 18, 2009 | Tomtom GO 300 GPS Receiver
Be-300
The password is an easy thing to get rid of. The problem is, a full factory restore is required. First do a hard reset and then restore the BE300 to factory defaults. The password will be reset.
Hard Reset: Press and hold the Power Button. At the same time, press the rest button on the left side of the device with the stylus (pen). You will see a blue scroll saying Initializing. Press and hold the OK button. Once the Initializing is done, the BE300 will go into the Safe Mode screen. Press OK and follow the instructions to the Restore Screen. From here, you can perform a Factory Restore but you need the original CD or a download of the Factory Restore BIN file.
For full BE-300 support, go to www.be300.org It's dedicated to the BE300 and everything you will need is there.
May 19, 2008 | Casio Cassiopeia BE-300 Pocket PC
Philips DTR220/05 digital freeview reciever not recieving anymore
If the box is still receiving some channels, then the box is probably not at fault.
If you have done the full "First time Installation" rather than search for new channels, then eithe the aerial, connection or signal is likely to be to blame.
There have been several changes with the Freeview service over the last few months, and there will be more in the run up to analogue switch off.
In some cases, channels have moved, and in other cases the service has been switched off for a short period, low power etc.
Check the aerial on a standard analogue signal, if the quality is poor, then this rules out the box.
Feb 23, 2008 | Televison & Video
Linksys Wireless-G WRT54GS Router (e125894) Logo
123 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
