Question about Canon PIXMA MP160 All-In-One InkJet Printer
Paper will not load..it is inserted properly and the roller is working it just wont pull through..the only thing i can think is that during installation when i loaded the paper i didnt press the black or color ink button..ive tried reloading and pressing but it doesnt register
    Novelist:
  • 154 Answers
The roller may be clogged and need to be pulled out and pushed back in. Upon doing so, you can do a restart. The more complex option would be to do a remove and reinstall of the printer and it's drivers. You would have to remove the printer completley physically and software wise on the computer under "Add Remove Programs". Once removed, and the computer is restarted, you can reinstall the software and then connect the printer. Make sure to pull out the printer roller to ensure there isnt any paper or accumilated dust blocking the roller from picking up the paper and it should work fine. If not, then you have a bad roller that may be damaged and missing a component.
Posted on Nov 14, 2009
Dont have the installation c.d. for Lexmark X5650, either. Plus, why does my printer pull the paper in crooked and WONT print! AND THAT CAUSES A PAPER JAM, then when you pull the paper out, the same t
Baring any damage to the load or eject trays, Check the back of the eject tray with a flash light by opening the top of your printer where you insert your cartridges. (make sure power is off first so that cartridges will not move over and be in the way.) . Next, check for any obstructions of paper, dirt, or foreign objects.
Next if there is nothing to be found, use a pencil eraser and a couple cue tips and rubbing alcohol to clean residue that builds up on the rollers where the paper feeds through. Screenshot
Close the top, make sure that the load tray is not damaged and is inserted properly. (You can remove the back 2 screws on the load tray and get access to the inside to check for any other obstructions and cleaning.)
Oct 22, 2014 | Lexmark X5650 All-in-One InkJet Printer
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
Tip
Paper does not feed properly
I was sick of the dreaded please load paper message I pulled the printer apart cleaned every thing to no avail. There is a roller on the right hand side where you feed the paper in. A small raised section behind the roller is used to pinch the paper between it and the roller. When this wears the paper will not feed. TO FIX Push a small piece of plastic it must be slippery (I used a 2 cm * 6 cm off an old xray) behind the roller Then use sellotape to hold it in place. No more dreaded load paper messages
on Jul 27, 2007 | Lexmark X5270 All-In-One InkJet Printer
Epson stylus sx405 will not load paper
Inspect the rollers that take the paper in. If none of them appear out of place or damaged, it may be that they need cleaning. I've had some success cleaning printer rollers with methylated spirits, but any dust cleaner should work.
Oct 01, 2012 | Computers & Internet
Cannon mp530 says load paper when paper is loaded
Paper not loaded error is displayed by the printer when the printer doesn't detect any paper. Here try this one.
  • Make sure that your paper is properly inserted.
  • If properly inserted and still the printer doesn't detect it. Try putting more amount of paper in the tray.
  • Be sure that there are no damaged paper in the tray.
  • Clean the rollers using a cotton buds and a clean water.
  • Now try printing again.
Hope my solution will help. Thanks for using fixya.
Jul 08, 2011 | Canon Office Equipment & Supplies
My Epson 1290 (some years old) doesn't grab paper, especially good inkjet paper) properly. It passes straight through, prints on the roller, and/or I get messages saying the paper isn't loaded properly or...
That could be from the rubber rollers not being able to grip the paper. They get polished or shiney over time with use and age. Then they slip or pull incorrectly and you get your problems. There are other things that can cause this but nothing worth fixing.
Fixing the rubber rollers is easy. You need some ispropyl rubbing alcohol and a paper towel. Make sure it is isopropyl type as this won;t attack other parts. Simpley wet the paper towel and wipe down the rubber rollers. You will see the rubber go from a dull shine to dull flat rubber. This takes off the buildup on the rubber and lets it grip again. Eventually the rubber will age harden and this trick won;t work but this can give you years more service.
Apr 20, 2010 | Epson Stylus Photo 1290 InkJet Printer
The printer wont load the paper in anymore it will grab it on the left side but not the right
Please help me here. What model printer are you using?
Does it have multiple paper trays?
More then likley, the paper feed rollers are either worn or contaminated with paper dust and are not letting the paper be grabbed and pulled from the tray properly.
It could also be the paper pick solenoid not mechanically pushing both sides of the spring loaded tray up into the paper feed roolers. Or in the case of a true paper tray, preventing both sides of the tray from lifting with the same force.
Don
Oct 17, 2009 | Dell 924 All-in-One InkJet Printer
Hi My Dell Laser 1815 is having a paper jam problem each time it tries to load the paper from the tray.
The paper tray itself is probably missing a small peice. Look towards the front of the tray... there is a guide (about 2" wide) that, if you push down, it springs back and forth. My tray was missing a small peice of flat metal that popped off. The feed roller rests on this piece when the tray is loaded. If the piece is missing, then the roller is to close and the paper cannot make it through into the printer. Still looking for the part number....
Sep 07, 2009 | Dell 1815dn All-In-One Laser Printer
I have an Easy Share printer dock series 3 that has paper loaded
Dirty rollers? I had the same problem and think the rollers are no longer sticky enough to pick up the paper due to a coating of dust... maybe cleaning the rollers would work?
Jan 28, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
125 people viewed this question
old marine
old marine
