Question about Nokia N95 Cellular Phone
I but nokia 95n and it was off i don't know how to turn it on?
Nokia e61i contacts recovery
Here's how to reset a Nokia E61i to it's factory settingsTurn off the phoneHold these three buttons simultaneouslyCall Button (the green one)The letter "Y" (the number 3)The letter U (the star key)Turn on phone (don't let go of the three buttons!)Only release the buttons when the phone is really on (when you see a bright Nokia logo).
That's it. Weird, but true. Don't know if you can do it through the menus, which should be easier...
Jun 21, 2012 | Nokia E61i Cellular Phone
I connect my nokia 6300 to the Ovi for update. At the end of dowloading, phone just shutdown before it end. Now i can't turn it on. How to solve the problem?
Dear did you know the disadvantage of Nokia PC suit and Ovi suit ?Don't try to do it again because during updating the USB connection frequently lose.Those who advise you to do this have less experience.In my opinion Pheonix is the best is the best solution if we don't want to contact mobile tech.So try this
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 6300 file or Nokia flash file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gifInside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck.If you could not do please contact me.
Jul 25, 2011 | Nokia 6300 Cellular Phone
Phone on then went code.i don,t know code
If you don't know the Lock Code means You can master reset your Nokia 5130 Phone,You can get the master reset code from here Unlocking4u
and reset the Phone...
Jul 17, 2011 | Nokia 5130 Cellular Phone
I have nokia n97 mini and I don't know how to turn of screensaver, it starts everytime even when the phone is lock and its some stupid nokia ovi commercial, please help me to turn it of
Welcome to FixYa.
There is no way to turn off the screen saver of Nokia n97 mini. The best thing that you can do is to choose another screen saver that you like.
To modify settings for automatic screen and key locking, select Menu > Settings and Phone > Phone mgmt. > Auto. keyguard.
Thank you for using FixYa.
Have a great day.
Jas247
Jun 05, 2011 | Nokia N97 Cell Phone
My Nokia 2330 has been corrupted and i cant turn it on.
your phone firmware is crashed you need to connect it with your pc having pc suit and update it if
you don't know how then take it to repair shop they flash your phone with new firmware.
May 31, 2011 | Nokia Classic 2330 Cell Phone
VIN NUMBER LOCATION
on the steering head on the frame, in between the upper and lower triple clamps.
Apr 13, 2010 | 1994 kawasaki ZZR 600
My nokia n73 failed to start up and i don`t know
switch of your phone then press calling key (green button)+3+* and then switch on your phone. don't release the keys for an minute. then your phone will be formatted and it will be ok.
Nov 07, 2009 | Nokia N73 Cellular Phone
Nokia 3120 phone restricted code
hello
1_ can you save your formation in other phone .
2_that code format your phone for Nokia only
3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345
4_ other numbers *#7370# and the security n ......
and look if the problem is solve it
because after this . you have like a new mobile
Jan 26, 2009 | Nokia 3120 Cellular Phone
Can't connect to KCA-BT100, with my mobile
0000 is the default BT code for most BT items.  0000 worked when I sync my phone with the Kenwood.BT100
Nov 10, 2008 | Kenwood KCA-BT100 Wireless Headset
Nokia N95 Cellular Phone Logo
35 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
