Question about Frigidaire Affinity ATF7000E Front Load Washer
The door locks for a few seconds, then unlocks, and nothing happens. The door lock light goes out. Code E-68
    President:
  • 2,049 Answers
Code 68 = Current leakage to ground on heater or fuse opened.
It can be a bad heat element, possibly a loose wire or as has been reported before, the insulation on the wire has fraed and is grounding againt the metal washer casing.
Unless you have a good electrical background, I strongly suggest calling an appliance professional to come in and fix it.
Posted on Nov 14, 2009
Load got off balance, I believe, and now it will not come on.
It sounds like bad electronics or bad sensor, did you try to adjust front door while turning machine on, like push them in. Do water runs in, if not it can be water switch.
Apr 04, 2016 | Washing Machines
LE error code has popped up & suddenly the control lock is on, I have pressed the control lock & it counted 3,2,1 & nothing happens, won't unlock & LE is still there
if the door locks and wont unlock
LE error
then your machine still has water in it from the last spin/ wash
i think its a blocked up waste outlet
or the pump is blocked up
you need to check the machine is draining correctly and in a timely manner.,..
or it will fail
you need to fully drain the machine then turn off the mains
wait 5 mins and the door will then open
then check the drainage...
Feb 08, 2015 | Washing Machines
How to program my new control remote to my Honda passport 2000
Try this please!
'98 - '02 Isuzu Rodeo and Trooper and Honda Passport(with factory keyless entry) Instructions for programming. 1. Get in car and make sure all doors are unlocked. 2. Open driver's door and leave open. 3. Put key in ignition. 4. Turn key to 'on position' (dash lights on, but do not start) and back to 'off position' 3 times in 5 seconds or less. (you must turn the key very fast) 5. Close and open driver's door 2 times in 5 seconds or less. 6. Turn key to 'on position' and back to 'off position' 5 times in 5 seconds or less. (turn key very fast) 7. Close and open driver's door the doors should lock and unlock twice after this happens push the lock or unlock button on the remote, doors will lock and unlock. Push the lock or unlock button a second time and doors will lock and unlock again. You are finished! The above sequence erases all previous codes and adds the new code as #1. If you are adding a second remote, you should follow the same sequence with the exception of step 6; instead of turning the key to the 'on position' and back to the 'off position' 5 times in 5 seconds or less, do it 3 times in 5 seconds or less and then continue to step 7. ***Remember to turn the key to the on and off position very fast. This works! Follow directions EXACTLY. I had to try 3-4 times before getting it to work. I failed to go exactly by the instructions the first few times.
Jan 03, 2013 | Cars & Trucks
Garage door wall opener will not unlock. I pushed unlock button and green light quit flashing, but door ony goes up a few inches. Have held the unlock button in for 3 seconds and still door will not go...
The lock button has nothing to do with your problem. It sounds like you have a bad drive gear. Remove the cover from the motor unit. The gear is white nylon and it will be obvious if it is the problem.
Jan 16, 2012 | Sears Craftsman LiftMaster Chamberlain...
Getting error code LO and the door will not unlock
To unlock the door on most Samsung Washing machines:
Press "end of cycle" for over 5 seconds or press "options & select" until the light goes off.
Else, try holding the buttons "dry" & "spin" together for a few seconds until the lock goes off.
Apr 24, 2011 | Samsung Washing Machines
I bought a new Keyless remote for a 2007 Forester from a Subaru Dealer to replace an original one that went bad after 2 years. I have followed the directions in the owner's manual to program it, but can't...
IMPREZA: 2005, 2006, 2007 and
FORESTER: 2005, 2006, 2007, 2008
Check for Immobilizer key on Forester XT models only.
information is always subject to change and correction imp05keylessremote1.jpg
new remote for 2005 Imprezas.
This is not the same remote as the 05 Legacy/Outback remote which also has truck/gate release on the front and a red panic button on the back.
Lock: press Lock button for 2 seconds or so to lock car, and arm optional security system. The car with chirp once and turn signals flash for locked, 5 short chirps and signal flashes if any door is not fully closed. The dome light goes on for 15 seconds and ignition key ring (if present) will light for 30 seconds when unlocked.
Unlock: press unlock one time for driver's door, press again within 5 seconds to unlock all doors inkling rear gate (wagon). The system does not open the trunk.
Panic mode: press and hold lock button for approx. 3-4 seconds to activate Panic mode. I panic model the horn honks and turn signals flash until either the lock or unlock button is pushed again.
Finder mode: Press lock button 3 times within 5 seconds to activate Vehicle Finder mode. The horn will honk once and the turn signals will flash 3 times
Distance: works within approx. 30 feet depending on battery strength, nearby concrete walls and etc.
Audible Chirp On-Off: the system will chirp when locked or unlocked. To turn OFF the chirps, unlock the door and then push both lock and unlock buttons at the exact same time for 2+ seconds. There will be 2 chirps indicating the the audible is off. To turn the chirp back on, repeat the process and the system will chirp one time when it is back on.
Battery: as the battery ages it will only work as you get closer to the car. When a battery is replaced, the transmitter must be re-synchronized with the Keyless control unit. To synchronize, press the lock or unlock button 6 times.
Programming: 4 codes may be programmed.
Sit in driver's seat and unlock all doors. Open and close the driver's door
Turn the ignition key from LOCK to ON position 10 times within 15 seconds. Be sure to stop at both lock and on. The horn will HONK once to indicate transmitter programming mode is activated. Leave key in LOCK position and don't remove it from ignition.
You now have 45 seconds to complete the programming as below.
Open and close driver's door again.
Push either lock or unlock button on the remote you want to program. The horn will honk 2 times when successful.
To continue and program other remotes at the same time: open and close the driver's door and push lock or unlock on the remote. The driver's door must be opened and closed between each remote you want to program.
Done programming? remove the key from the ignition and the horn will honk 3 times.
DELETE old codes? Reprogram 4 times, it will overwrite old codes.
Alarm Security System: optional on all models. When locked there is one chirp (can be turned off, see above), the turn signals will flash and the red 'security' light will start to flash once every 2 seconds except for STi which flashes twice every 2 seconds.
There will be 5 chirps if a door, hood, and trunk or gate is not fully closed
You can also arm the system by using the power lock button on the driver or passenger door as you get out of the car and then closing the door behind you.
Disarm the system: push unlock for 2 seconds
Lost remote, alarm activated? When you can't use a remote to turn off the system: open the door with a key or try to start the car and the horn will start to honk. Turn the key on-off 3 times within 5 seconds and the alarm will go off and you can start the car. It's simple!
VALET mode: To set valet mode or just to disable the security alarm system: 1. unlock all doors 2. physically open the driver's door 3. hold the UNLOCK button on remote for 2+ seconds. The red 'security' light will then flash 2 times a second until the car is turned on.
System has been Tripped (except for STi): if you unlock the door with the remote and it chirps the signal light flash 4 times, the system has been triggered;
Identification mode: To find out what happened and why the system was triggered:
Open and drivers door, leave it open. Turn ignition key from LOCK to ON 2 times and then leave in LOCK position.
Tripped code: 1 security light flash: a door has been opened, 3 flashes when the impact sensor was triggered, 4 flashes when the ignition was messed with or battery disconnected
Nov 19, 2009 | 2007 Subaru Forester 2.5X L.L. Bean...
WINDOWS COME DOWN BY THENM SELF NO ALARM GOES OFF DOORS ALSO UNLOCKS
if you hold the key in the trunk or drivers door, to the unlocked position for a few seconds the doors will unlock and the windows will all go down. usually when this happens by its self the body controll module is to blame. it could be the electrics on the drivers door lock broke in the unlock possition. the door handel/lock is a nightmare to replace. i would get a used body controll module and plug it in and try that first
May 25, 2009 | 1996 BMW 318
Coding a key for a renault laguna
Renault Laguna II Key Remote Control Programming
LAGUNA II INFRA RED RESYNCHRONISING
1. Turn the Ignition OFF.
2. Press the central door locking button for more than 5 seconds. Note: the door should lock then unlock.
3. When this happens 15 seconds is allowed and the immobiliser warning light illuminates.
4. Point the 1st key at the receiver and press the button once, the doors should lock and unlock.
5. Point the 2nd key at the receiver and press the button once, the doors should lock and unlock.
6. Check the remote control unlocks and locks the doors.
Mar 24, 2009 | 2004 Renault 181
Frigidaire stove door locked
I've had a similar problem - door is locked. If the door is open - locate the light switch and hold it in for a few seconds. Sometimes it makes a noise and resets the lock. Otherwise, push the Clean button and the Cancel button on front of oven simultaneously and hold for about 30 seconds. The ?locked? light should disappear. If it is working, you?ll hear a mechanical hum as it resets.
May 10, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire Affinity ATF7000E Front Load Washer Logo
269 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
