Question about LG Shine KE970 Cellular Phone
I have a weird symbol on the screen its a grey line with 2 circles
  • 3 Answers
If you wanna get rid of this just go to menu/settings/display/home screen shortcut then choose on or off .There you go!
Posted on Nov 21, 2009
What is the meaning of the various symbols on the line with blutooth and charge percent etc. In particular, the symbol with a lock with a circle around it?
The lock with a circle around it means you have locked the screen rotation. This means when you rotate the device, the screen will not rotate.
If you want to turn off the screen lock, just swipe up on your iPhone screen and turn it off in the panel that appears.
More information is available on the Apple website: https://support.apple.com/en-us/ts3805
Hope that helps!
Mar 12, 2015 | Apple iPhone 5
Tip
How to create motion across the screen?
Step 1
Create a small circle to the left in the Stage area. Do this by selecting the circle tool from the left toolbar. Draw the circle in the Stage area.
Step 2
Select the Arrow tool from the left toolbar. Double-click on the circle to select it.
Step 3
Now we have to convert the circle to a symbol. When the circle is converted to a symbol we can create instances of the circle. From the top menu choose Modify > Convert to Symbol. Name the symbol "Ball", and select OK.
Step 4
Go to Frame 10 in the Timeline. Do this by clicking the gray field below 10. Then right click in this field. Choose Insert Keyframe. Keyframes appear as circles in a frame. This operation duplicates the image.
Note: A keyframe specifies changes in an animation. You create keyframes at important points in the Timeline and let Flash create the frames in between.
Step 5
Select the circle and move it to the right a couple of inches.
Step 6
Click on the Timeline any place between Frame 1 and Frame 10. Then right click and choose Create Motion Tween.
Step 7
Choose Control > Test Movie from the top menu to test your Flash movie.
on Aug 11, 2008 | Adobe Flash® CS3 Professional Full Version...
Relay on 96 mustang
I am not sure exactly what your question is, but the relays in your mustang are located on either the under hood fuse box or the CCRM, which is located in the passenger side fenderwell. To do a bench test on one to see if its working, simply locate the relay in question and unplug it.Look on it's side and you will see its schematic with numbers at either end of two symbols. One symbol will be a straight line with a circle at either end and the other will be a circle with a line running from it at 45 degrees with a circle underneath it when that line ends.
Get two wires and attach one to your cars battery positive and negative terminals. The pins on the bottom of the relay are numbered. Match the 2 pins that match the numbers for the symbol with the straight line with a circle at each end(numbers will be next to the circles) and touch one wire to one pin and the other wire to the other pin. You should hear an audible click. If you do then the relay is good, if not the relay is bad.
Feb 14, 2015 | 1996 Ford Mustang
The symbol is a round orange circle with ! sign inside and lines
Brake pads require checking
This warns you early so you don,t ruin discs
Dec 24, 2009 | 2007 Mercedes-Benz SLK280 Roadster...
No sound on Powerbook G4
hey,
so not to be obvious but you have one of two problems either hardware or software. there is a way to check but you need to do a few things. first you should try creating a new user account and see if the volume problem still exists. you create a new user through system prefs/accounts. if that doesn’t work you should try a pram reset by holding down the cmd, option, r, p, key at boot. IF you have never done this before you want to hear the startup chimes at least 3 times then let the computer restart. if that still doesn’t work you should try an archive and install of the os from the discs if you still have them, and if none of that work you most likely have a hardware issue and either the logic board needs to be replaced or the speakers are bad. but either way its going to cost money if there is a hardware issue and you might consider a new computer, im just being honest.
Aug 20, 2009 | Apple PowerBook G4 Mac Notebook
HTC Touch Diamond 2 (E) sybol problem!
E symbol is to indicate htat you have active EGprs connection....
This E symbol gets greyed out only , when you are out of reach or when you dont have proper sgnal..
Since the signal is very less, you were not able to send or receive SMS or Call..Try checking with open space...No Issues with your mobile
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 07, 2009 | HTC Touch P3450 Smartphone
8310 BlackBerry start-up symbol
you must fullflash your BB to work it again.you can use desktop manager 4.7 to flash your phone.
and here you can download firmware:http://na.blackberry.com/eng/support/downloads/download_sites.jsp
Jul 25, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blue Dots at bottom of screen
i have 6 grey perfect circles on screen of sony 52 inch kdlw3000
Jul 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Weird lines, characters, symbols etc.
It sounds like you need to put in a new set of back-up batteries. They can be found behind where the AA batteries are.
Aug 17, 2007 | Texas Instruments TI-83 Plus Calculator
Sanyo Flat Screen (DS27910) "Grey" Screen
dont know for sure but i think that the tube is going bad. Have one in my shop doing almost the same thing.Taped on the tube and it does strange things. My tube tester wont test this kind of tube that is in these sets.Not much help but it is a start.
Sep 17, 2006 | Sanyo DS27910 27" TV
LG Shine KE970 Cellular Phone Logo
64 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
