Question about Mitsubishi VS-6047 60" Rear Projection Television
Mitsubishi Vs-6047 Convergence Problem...Please Help!
My problem I believe is a convergence problem. Last night the green in my tv started bowing and was off from the other colors. Red and Blue are lined up right but the green is far from lined up and is bowed top and bottom. I have read that it is probably my convergence amp ics. If that is the problem where are they, how many of them and where can I get the parts? Thank you!
    Genius:
  • 1,030 Answers
Usally convergence green is split between 2 ics. so if your blue and red are still good. it might be the green output resistors. The
Posted on Jan 08, 2008
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Mar 22, 2012 | Mitsubishi VS-45603 45" Rear Projection...
Hi, I have the ws-65907 65", it was working last
No,this problems is not the projection lamp problems.The tv now have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or look like 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like 300-350 for parts and labors.
Oct 26, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Tv turns on. There is a picture but it looks like your looking through a fish bowl. Bowes into the middle from both sides. It also looks 3D. Any Clue??
This is usually a convergence problem, although the bowing normally is from the top and bottom rather than from the sides. There may also be an issue with the pioncushion circuit that causes the bowing. Try the automatic convergence adjustment first. If that fails to resolve the problem, then resoldering the convergence ICs would be next followed by replacing the ICs should the resoldering fail.
If you wish to attempt the repair, please update this and confirm the model number to be VS-60607 and I'll provide additional details.
Thanks,
Dan
Dec 08, 2009 | Mitsubishi VS-60607 TV
I have a Mitsubishi VS-60607 Tv and it started out
Without going in with troubleshooting equipment it is hard to determine if the problems are related or not but it is unlikely since you seem to have a video problem and a convergence problem , which are two separate circuit(signal processing and deflection). Hope this help.
Please do not rate this answer(unless it helps)as it is only a suggestion.
Dec 03, 2009 | Mitsubishi VS-60607 TV
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Need info onhow to fix
Fix convergence issue first = bowing / distortion will go away.
Requires changing large STK IC's and possibily a pico fuse
in the power supply......................T.
Oct 23, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs 60719 - Wavy bow in picture
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Jan 28, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Televison & Video Logo
207 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
