Question about Lexmark X4270 All-In-One InkJet Printer
Error #1200 is running across the screen. It seems that the ink cartridges are somehow stuck and I can't find my manual.
  • 6,831 Answers
Hello
This link will show you exactly what the error message means, and how to fix it.
http://support.lexmark.com/index?page=content&id=SO3439&actp=search&viewlocale=en_US&userlocale=EN_IN&segment=SUPPORT&productCode=LEXMARK_X4270&searchid=1258162400715
As for the manual you lost, just click on the link below and download the manual from there.
http://www.retrevo.com/s/+Lexmark+X4270+All-In-One+InkJet+Printer
Kind regards
Andrea
Posted on Nov 14, 2009
After I changed ink cartridges on my Lexmark ExecJet IIc printer/scanner/fax/copier, and shut teh top down it comes up with error: 0502 When you lift the top up again the print head does not move across,...
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge1.gif carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable1.gif from the back of the Lexmark5.gif X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges1.gif.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up1.gif to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
If that doesnt work let me know..
Please rate accordingly
Thank You
Computerrep
Apr 02, 2008 | Office Equipment & Supplies
The printer will not print. Hardware Error: 502 appears on the screen. I have followed the manual correctly but the problem still exists
Try this
2. Disconnect the power cable from the back of the Lexmark printer X5150.
3. Leave the power cable disconnected for 40 seconds.
4. Reconnect the power cable and switch the printer on again.
5. When the printer powers up, you will need to select the desired settings.
The 0502 error problem possible causes:
1. A dirty encoder strip
2. A faulty black/photo ink cartridge
3. A faulty color photo ink cartridge
4. The encoder strip being out of position
Mar 01, 2010 | Office Equipment & Supplies
Error code 1200 is showing?? help!!
The error 1200 indicates that the cartridge carrier is stuck inside the printer. Please follow the steps given below:
1. Unplug all cables from the back of the printer.
2. Open the front cover and look above the steel rod. You should see a black belt with rubber teeth on it. (On some models, the cartridge access is very small, but the belt should still be visible.)
3. Take the top part of the belt and move it gently to the right. The cartridges should come towards the center.
4. If the cartridges will not move, tilt the printer on its back and try moving the belt again.
5. If it still will not move, try putting your finger inside the area where the cartridges are stuck (with the printer still on its back), and push them firmly against the cartridge carrier holder while you move the belt with your other hand.
6. Once the cartridges are in the middle, snap them firmly into the cartridge carrier. Note: Make sure that these cartridges are the correct models for your printer. Once the cartridges are seated properly, they should not become loose inside the carrier.
7. Plug all the connections back in and power the printer up.
8. Open the front cover again to see if the cartridges slide to the center.
You should then try to self-test the printer. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in and follow these steps:
Next, try this printer self-test by following the steps given below:
1. Press the "Copy" button once.
2. Press the "Options" button 11 times until the screen reads "Maintenance."
3. Press the "Left Arrow(-)" button until the screen reads "Maintenance: Self Test."
4. Press "Select."
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 01, 2009 | Lexmark X4270 All-In-One InkJet Printer
Indicator light remains lit even though it is a full cartridge
It seems there are "new" chips & "old" chips in these ink cartridges for the HP 1200 inkjet printer. I have a cartridge with a "new" chip in and it is working fine. The printer doesn't read the "old" chips. Something to watch for when using refilled ink cartridges.
Apr 17, 2009 | HP Office Equipment & Supplies
HP 7830 printer: changed black ink cartridge, prints windows test page then errors, cartridge gets stuck halfway across during printing.
Thanks for posting in FixYa.
It seems that the Cartridge is now correctly fitted in the printer. Please remove the catridge during Power off and then install it firmly. Reboot the Pc and power on the Printer. Hope it will fix the issue.
Let me know if you need further assistance.
Regards
ELLIN
Sep 20, 2008 | Office Equipment & Supplies
Ink cartridge
Not quite sure what you mean but if it is stuck under the housing then that would give the error. Could it be that the cartridge wasn't installed straight and this has caused it to become jammed?
Oct 08, 2007 | Dell 922 All-In-One InkJet Printer
Error 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Oct 03, 2006 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
