Question about Nokia 3310 Cellular Phone
My phone does not power on sometimes.scroll key and no.3 key not functioning
How to recover my input power on password in micromax x101 mobile
if your phone is android follow this instructions
1. Switch off the device
2. Hold the POWER key together with at least the down volume key to power the phone and start the resetting process.
3. A command-like window with sometimes a green text appears
4. Use the up/down volume keys to scroll screen and use the Power key to select.
5. Select WIPE DATA and the phone reboots after some few minutes to clear and reset your device memory.
May 05, 2014 | Cell Phones
How do I master reset the phone lock code for my ZTE G N290?
Hard Reset: 1.Power OFF the handset. 2.Now press and hold the Volume Up, Muve Music key and the Power keys for 10 seconds. 3.A test screen (Triangle / Exclamation mark) will be displayed as below. 4.Press the Volume Up and Volume Down keys simultaneously to access the System Recovery screen. 5.Scroll using Volume and select "Wipe Data/Factory reset" and press the Muve key. 6.Scroll using Volume and select "Yes - delete all user" and press the Muve key. 7.When complete the system recovery screen is displayed. 8.Select "reboot system now" and press the Muve key. Master Reset: 1.Tap the Menu key 2.Tap Settings 3.Scroll to and tap Privacy 4.Tap Factory data reset 5.Read the message about erasing data 6.Tap Reset phone 7.Tap Erase everything.
Mar 30, 2014 | Cell Phones
Screen keeps shutting off
Hello, it looks like you either have a malware (very rare) or a corrupted ROM (firmware). Now, you can try to hard reset your phone. Even though I have no information if the phone is rooted or not, try the next steps:
1. Turn off the phone, in your case, it can't stay on, so let's say this step is already cover.
2. Press and hold at the same time: Camera key, volume up and power key, and let them go ONLY 2 or 3 seconds after the Android logo is display.
3. Scroll down to Wipe Data/factory and highlighted, tap home to choose, scroll down to yes and tap home to select.
4, Go back to the main recovery page and do the same thing but with Wipe Cache as you did with step 3.
5. Once that is down, go back to the recovery main page, scroll up to Reboot, and tap home to select.
This process is to clean your phone and leave it as brand new, as when your first bought, if it wasn't bought second hands or used. In most case it does fix the problem with the firmware and fixing the permissions need in order to function properly. If after this you still have a boot problem, then your device needs to be flash with a new firmware.
Mar 11, 2014 | ZTE Warp
It is like my function key is always on. i cannot use delete instead the scroll lock is being activated
Deactivate the scroll lock key by pressing it one more time. The Scroll lock (Pause) key is a remnant of the old text-based displays. It works in DOS mode. Also unlock CAPS key. The Fn key is a control key for the Function keys (F1-F12) and sometimes the ESC key also.
Oct 05, 2013 | ASUS Eee PC 1005HAG Notebook
Release the scroll key
    • 1 Open and power on the laptop.
    • 2 Wait for the laptop to fully boot.
    • 3 Locate the "Scroll" button at the top-left of the keyboard. It is under the volume panel and between the "F12" and "Pause" keys.
    • 4 Press the "Scroll" button.
    • 5 Test it by opening a spreadsheet and using the arrow keys to move around on it. You can open your Microsoft Excel program or create a spreadsheet online by using Google Docs (free online productivity software). The "Scroll Lock" function will keep the current cell selected while the screen moves.
    • 6 Press "Scroll Lock" again to turn it off.
Apr 17, 2012 | Logitech Cordless Desktop MX3200 Keyboard...
How do you use the Redial function?
Redial in ITR-8D-3 IP Phone
Press key to activate redial feature. Press redial and scroll back through
numbers that have been dialled. Until the desired number is displayed. Press the * key to activate dialing
Nov 05, 2009 | NEC ITR-8D-3 IP Phone
Is there a reset option on the samsung red rant i am umable to power on and i have a new battery
Try a Hard Reset:
Hard Reset will reset the phone to its factory settings and erase all data.
1. Press the MENU/OK key to select the MAIN MENU tile.
2. Scroll Up to Settings and press the MENU/OK key. 3. Scroll Up to More and press the MENU/OK key. 4. Scroll Up to Security and press the MENU/OK key. 5. Enter the lock code. For this example, press 7 to prompt one to fill in. If you can’t recall your lock code, try using the last four digits of your wireless phone number. If this doesn’t work, call Sprint Customer Service at 1-888-211-4727. 6. Scroll Up to Erase/Reset and press the MENU/OK key 7. Scroll to Reset Phone and press the MENU/OK key. 8. Read the Warning and press OK (Left Soft key). 9. Scroll Up to Yes and press the MENU/OK key. 10. Scroll Up to Yes and press the MENU/OK key to complete the reset. 11. For this example, once the reset is complete, scroll Down to No to decline to verify Wireless Backup
Oct 23, 2009 | Samsung Rant Cell Phone
My phone is set in Italian. How do I change the
My phone is set in Italian. How do I change the language to English?
Jul 06, 2009 | Cell Phones
Won't scroll to top of page. Stuck at the bottom! Fixed momentarily by pressing scroll lock key or F7 key, but goes back to the bottom seconds later. (I also have issues with the F7 key, and the touchpad...
It sounds like your scroll lock key is stuck on. Press the Function key and the scroll lock key at the same time and this sound turn off the permanent scroll lock.
Feb 27, 2009 | Acer Aspire 5570-2758 Notebook
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Nokia 3310 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
