Question about Kicker KX120.2 Car Audio Amplifier
Blowing the amp fuses
I ran wires in my 99 dodge ram for this amp. One directly from the battery for a 12 volt supply, one from the cigar lighter power for the remote. And one ground directly to the body via self drilling screw under the carpet. With a good fuse in the amp, as soon as I go to hook up the last of any one of those wires the fuse pops immediately. Where did I go wrong? Or have I caused damage to the amp.
  • 4,402 Answers
Do you have speakers connected as well? do you have a volt meter
make sure you are getting + from both are you sure the remote is not a 5 volt line?
Posted on Jan 08, 2008
Fuse location diagnostic connector 2002 ford excursion sorry I have no manual.
It is fuse number 12 in the interior fuse box behind the panel just to the left of the steering column.
Fuse #12 a 20 Amp mini fuse that powers the Cigar lighter and OBD2 diagnostic connector pin #16 (12 volts)
Dec 17, 2016 | 2002 Ford Excursion
My cigarette lighter isn't working? Can it be a burned out fuse?
The fuse could be burnt out, the lighter coil could be burnt out, or the hot wire or ground could be loose.
Mar 03, 2015 | 2005 Mazda 3
After tapping into the ignition wire to connect the remote wire for a amplifier the 15 amp fuse keeps blowing when I try to start the car. What should I do?
a car amplifier should use an outdoor 2or so gague (very thick_) wire, ran, not to the fusebox, but to the battery, with a 20-30 amp under the hood, within a foot of the battery. the amperage your fuse will rewquire is based on the formula amps= wattsdivided by volts. a 240 watt amp on a 12 volt line would need a 20 amp fuse, just for the amp alone.
Dec 21, 2014 | Car Audio & Video
2005 Jeep Wrangler Heater and Cigarette Lighters not working.
May help - fuses supply power but also needed is earth return to battery. This is usually black wires running from device to the car metal. To diagnose you need a multimeter. Check body of cigar lighter is connected to the chasis with meter on ohms. (continuity test) good is zero ohms. If earth problem, check under dash to ensure all earth wires connect to metal chassis. Then with ignition on, check centre pin at back inside cigar lighter has 12 volts to side.
If not then check fuse has 12 volt to it, Now you can get to the fan, repeat all the tests on fan. Best wishes, its tedious work.
Jan 03, 2014 | 2005 Jeep Wrangler
30amp auto shutdown fuse blows is it alternater
The ASD relay supplies battery voltage (12+ volts) to the fuel injectors and ignition coil(s). With certain emissions packages it also supplies 12-volts to the oxygen sensor heating elements. The Fuel Pump Relay is a separate relay controlled by the ASD relay input to the PCM. Fuse #12 (10amp) provides 12 volts to the coil side of both the relays and the ignition switch. Fuse #6 (30 amps) supplies 12 volts to the output side of the relay. Fuse #16 (15 amp) from the relay output to the Oxygen Sensors and Fuse #26 (15 amp) relay output to the PCM. Fuse #24 (20 amp) is Fuel pump relay output to fuel pump. Fuse #19 (10 amp) supplies 12 volts direct to the PCM.
look for burned or melted wires in the offending circuit.
sounds like you wiggled a wire while installing new relay.
Mar 06, 2013 | Cars & Trucks
99 dodge no tail or dash lights keeps blowing fuses
the dash and tail lights are ran on the same fuse/curcit your shorting to ground somewhere along the lines. check for a broken bulb melted wiring or a broken wire
Aug 30, 2012 | 1999 Dodge Ram 2500 4WD
Using cigarette lighter for air pump
It is very likely the cigar lighters circuits wiring sizes are not suitable for the amp draw of the compressor, i suggest you not use it as a power source. Buy clip leads and solder them on and use the battery as the power source. You can obtain the electrical clips from any hardware store.
Jul 23, 2012 | 2006 Honda Jazz 1.5
I have a 2005 Dodge Ram 1500 5.7 hemi. I have to replace the EGR since erasing codes numerous times has not helped. Do I need the PCM flashed after replacement? Thanks
Hello! No, not at all...After you change the EGR, disconnect the + battery terminal for 3-5 minutes...Reconnect...And if the EGR was the cause of the fault the code will clear...Make sure you have the stereo code...If not, connect a regular 9 volt battery to a cigar lighter plug (pay attention to polarity)...Plug it into the cigar lighter socket before you disconnect the battery...It will maintain power to the stereo...Guru...Saailer
Dec 25, 2010 | 2005 Dodge Ram 1500
1996 Cavalier 12 Volt power outlet in car doesn't work right?
Even thought the plug in is 12 volt. It's ouput is different. Most electronics have different ranges from 3-9 volts.
Does the 12 volt charger put out 12 volts? If so, it would burn up the electronics' capacitors on their power supplies.
How is the car's electronics doing? Are they too failing? If so, that would be a faulty voltage regulator, if not, I would hook up anything you use to the radio wires.
You cannot plug in anything directly to battery no matter what the person told you. Batteries charge, than release charge, a contiuous cycle. The power output is speratic and anything hooked straight up to the battery will need a fuse.
Jun 08, 2009 | 1999 Chevrolet Cavalier
Tottom direct power supply
No, it will fry the unit!!!
You need the cigarette lighter adapter to bring the voltage down to 5V. More than 5V will fry the One.
Apr 02, 2009 | Tomtom ONE 3rd Edition GPS
Kicker KX120.2 Car Audio Amplifier Logo
80 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
