Question about D-Link AirPlus DI-524 Wireless Router
My router suddenly stopped working and I don't know why. It gets power. Both the status button and the WLAN button blink on and off. I think it just died and needs to be replaced. Any ideas how I can tell for sure? I can connect normally via my modem. Thanks.
  • D-Link Master
  • 6,487 Answers
Try first to reset the router so we can check if we can still make it work, To reset it Press and hold the reset button of the router for 30 seconds while power is ON and after that reconfigure the router but if still doing the same thing router is already bad and needs replacement.....
Posted on Nov 14, 2009
Testimonial: "Thanks! I did what you said and it actually worked! Wow! Thanks!!!!!"
I have a Linksys WRT54G2 Router, It Has Worked Fine For About A Year, And Just Suddenly It Has Problems, The WLaN Light Isn't On At All, The Power Light Is Just Blinking At A Steady Rate. I Can't Access...
Please make sure that Power, Internet and Wireless Light (or LAN light if trying to connect with Ethernet cable) is there on router if you are trying to connect it wireless .
And if only Power light is there only.Please try to power cycle the router ( turn off the router from power supply wait for a minute, plug the power supply back) and then again check the light status.
Even after this if same light status is there please try to reset the router ( there will be small pinhole button on the back side of router) just press it for 15 seconds and then release it.Wait for 2 mins and check the light status again.
It will fix your problem.
Please share the results.
Dec 09, 2010 | Linksys WRT54G2 Wireless Router
Power on, status light blinking, wlan blinking, 1 & 2 blinking, but cannot pick up internet on laptop.
Is this a new installation? Or did it just happen, and was working before? Are you using DSL service or cable or dial up? Not enough info....
If it was working before, and suddenly stopped, then first thing to do is unplug the router for 30 seconds or so, then plug it back in.
If it was working on the laptop and stopped working, then you need to find the connection icon in the system tray (next to the clock) and right click on it, choose REPAIR from the popup. Let it finish and try to connect again.
If new installation, did you follow directions to install and use?
Open your Internet Options, and "connect" to the network. Wizard will walk you through it.
Start with the above - If no help then call back here.
Nov 12, 2010 | D-Link AirPlus DI-524 Wireless Router
Should the status light be blinking?
you should call the wireless manager.
good luck.
Jul 26, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
WLAN light not working, router not working
D-links, just die like this I have had two of them do exactly the same, so i would.t wonder if your has done exactly that too. They are pretty mass produced. You will have to get a new one.
Apr 23, 2010 | D-Link AirPlus DI-524 Wireless Router
Hi , my d- link wireless router just stopped working yesterday. I can't seem to get it to connect to the internet and none of the laptops are getting wireless internet. There are 2 lights that are blinking...
Verify the connections are correct, The WAN port should be connected to the Cable/DSL modem. Then do a hard reset (hold in the reset button for 30 secs). If this doesn't work, try another router to isolate the problem.
Sep 03, 2009 | D-Link DIR-625 (790069292637) Wireless...
WLAN indicator won't stop blinking when router is reset
i think blinking indicator is not the reason but if the indicator are not blinking that would be problem.. you are getting a internet provider, right! contact your internet provider for this problem because maybe its not your router in the problem or maybe them...
Jun 19, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
WRT54GS router stopped working
try holding down the reset button which should be behind or under the router for 30 seconds, still holding down the reset button turn the power off for 30 seconds, still hoding the reset button wait more 30 seconds. After that your router should be in the way it came.
Feb 24, 2009 | Linksys : WRT54GS Wireless-G Router W/...
Router WRT54G no Power led on
HAVE YOU PRESSED THE RESET BUTTON ON REAR OF ROUTER (LEFT SIDE).IF NOT TRY THAT OR FOR MORE INFO CONTACT TECH SUPPORT AThttp://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1149562300349&pagename=Linksys%2FCommon%2FVisitorWrapperRICHARDM69
Jan 03, 2009 | Linksys Wireless-G WRT54G Router
Cannot reset or access configuration page.
The PC will detect a closed loop within the Network cable so forget that. Sorry but the router is bad if you cannot access it and the reset button does not help.
Have to get another 1
Nov 11, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link DI-514 router not working after power outage
To reset your router, use the following steps:
  1. Press the reset button for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
  3. Open up your Web browser and enter 192.168.0.1 in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
The router has now been reset.
Apr 20, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-Link AirPlus DI-524 Wireless Router Logo
121 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
