Question about Maytag Performa PAV2200
Maytag top loader 5+years old
Have checked for blockage,dranaged,electric, ect. washer fills great, washes great, have a rubber smell when it tried to spin and water will not leave, found the cap with clips that hold the drum, was wet and dirty, removed and can see wetness between the drum and out side covering how do we remove the agater so we can remove the drum and clean out. It tried to turn, but again have the burning smell and squeak noise. The belts below the machine are good no breaks in them and turn with no problem
Thanks
Dale Davis
765 698 3720
filly47024@peoplepc.com
  • 589 Answers
Sounds like a water pump problem. Please specify the exact model, and I will link you to the disassembly instructions.
Posted on Jan 08, 2008
    Scholar:
  • 196 Answers
In the right rear of the machine is the water pump. Because of the way the washer works, this pump turns in both directions. From what you are describing, I would suspect the pump.
Remove the pump and turn it by hand in both directions. I'm sure you will find that the pump sticks and squeaks.
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
The washer bucket has developed a black mold & smells.can I fix?
first you have to wash the mold away the next solution is to go to home depot and pick up a product called affresh it cleans out the inside of your washer this is a once every 1-3 months product that will also prolong the life of your washer and all front loaders ive also found that this works great in top loaders as well
Apr 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag Atlantis washer
is the smell rubber or electrical? the pump could be seizing on it and burning the belt. check this out first.
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
My maytag neptune washer smells musty. what is
I owned a maytag neptune washer and had to run dishwashing liquid thru it occasionally to get the smell to go away. Finally we learned about a new gasket retrofit that they were doing which was covered by the maytag company we called and they installed it for free and the smell stopped. I had that washer for about 10 years and probably spent as much fixing it over the years as it cost. I now have a whirlpool duet front loader and love it. no smell and not problems. Try the electric dish washer soap.
Aug 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fills with water, agitates, won't drain
how to replace the Maytag belt at this location
http://www.repair-help.com/kb/index.php?article=187
Diagrams and belt orders here http://www.pcappliancerepair.com/model-display.php
Dec 05, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Maytag washer
lean the washer back .......
Oct 07, 2007 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
160 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
