Question about Nikon Coolpix 5700 Digital Camera
I am getting a this card can't be used error message and it's this same card I have always used. Help
  • 797 Answers
Try a new card and test it. A card can go bad, not often, but it has happened to me.
Also this camera uses compactflash. The pins could be bent, causing errors.
If you try another card, and still cannot read or write to it, then the camera needs repairs.
Another option would be to sell it on a site such as
Ebay for parts, as is.
Posted on Nov 14, 2009
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
Card error
Is this the card you always used, or did you recently buy a new card?
Because you can use MMC cards and SD cards. Most SD cards you now buy, even the 2 GB ones, are SDHC cards and they are not compatible with your camera.
You should try to get an SD card. They used to make SD cards up to 4GB, but as I said, now they already make 2GB SDHC, So look careful when buying a memory card.
If it was the card you always used, try to get all pictures from the card, using an external memory card reader on your computer. Then in the camera do a format, before you continue.
If it does not work, try an other card. SD that is.
Mar 01, 2014 | Aiptek PocketCam DV4500 Digital Camera
Nikon d90 dslr camera
hello, always update the firmware through memory card, and not through usb cable this may be error message may not come, in case you are already using a memory card, format a new card and ensure that nothing other than the firmware is there hope this helps
thanks and regards
from v.g.chimalgi
Nov 14, 2013 | Nikon D90 Digital Camera with 18-105mm...
Card error message
Without knowing the error I can not help you. I would recommend investing a new camera, or buying one used from amazon.com for $5.
Oct 20, 2013 | Fuji FinePix A340 Digital Camera
Memory card error for the Panasonic DMC-TZ1
What type and size memory cards? The DMC-TZ1 works with SD cards 2GB and smaller. It will not work with higher-capacity SDHC cards.
Mar 15, 2013 | Panasonic Lumix DMC-TZ1 Digital Camera
I get a memory card error message on my Pentax Optio S40. I bought two new memory cards. Sandisk 512 mb. I get the same message on them. I tried formating the card on my computer. When I pit it in my...
Camera cards are never to be formatted on the computer....only in the camera. "card error" usually always means you need to format the card in the camera. This will erase it so download any pics you want to save first.
Jun 02, 2011 | Pentax Optio S40 Digital Camera
I got a "card error"
Welcome to FixYa.
There are three reason why do you get a "card error" when trying to format your card.
* a new memory card or unformatted camera.
* a memory card that has a file, this camera can't recognise or one has been take from another camera.
* always format the memory card using the camera. If you insert a memory card that has been formatted using other cameras, memory card reader, or PC's you will get this error message (card error)
Feel free to send us your comments or suggestions if this solution was helpful.
Thank you for using FixYa.
Apr 11, 2011 | Samsung SL102 Digital Camera
Communication error????
Blame Microsoft updates. Try using a card reader instead...works every time.
Nov 23, 2009 | Canon PowerShot SX110 IS Digital Camera
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
I need help Please my printer won't print gettig an error
The error message is related to the card that connects the printer to the network. The card is most likely bad. You may be able to clear the message by turning the machine off for 20-30 min, however this does not always work. If the error persists, you should turn off the machine, remove the card (it is in the back where the cables plug in, it has a connector similar to a large phone cord and can be removed by loosening the two thumb screws and sliding it straight back) and hook the printer directly to the PC with a parallel cable. You can also order a new card (Part#J3113A) online, but it will take some time and needs to be configured after installation.
Hope it helps,good luck to your daughter with her paper!.
May 15, 2008 | HP LaserJet 4050 Printer
Nikon Coolpix 5700 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
