Question about Sanyo Midsize Compact Refrigerator - Metallic
It won't turn on. Its plugged in. The Thermostate is on MAX.
It won't turn on. Its plugged in. The Thermostate is turned to max. It there a switch to turn it on? It is not cool.
  • Sanyo Master
  • 1,606 Answers
Tap on the thermostat and if the refrig comes on , replace the thermostat .
Posted on Nov 14, 2009
Check thermostate on a samsung side by side frig rs2630sh
Set it to max setting, once compressor starts reduce setting to whatever you want to set it to. It should shut off once it reaches the temp you selected. If the compressor does not come on when set to max, unplug the unit, remove t/stat and jumper the two wires together. Plug it in, if the compressor then starts, replace the t/stat.
Aug 29, 2014 | Samsung RS2630SH Side by Side Refrigerator
What are the air and gas settings for a poulan micro XXV chain saw
adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
Aug 12, 2014 | Garden
When connecting negative cable it sparks and starts a blower on top of the motor, and the motor won't turn over, what do I have?
Steve: Tell me what engine is in the Max? Can you identify the "motor" you mention...by physical location on the engine?...Lastly, when you turn the key are you saying the starter motor does not run?...Guru...saailer
Dec 18, 2011 | 1992 Mitsubishi Mighty Max
MY Bosch Refrigerator (KGU3420GB) does not seem to chill the top fridge compartment but the freezer seems ok(-18). Any suggestions as to what might be the problem. I suspect the thermostate control. I have...
you will find either 1) there might be a ice blockage on the evaporator. This in turn can stop the evap.fan motor which is supposed to circulate the frost .Defrost with a hairdrier once panel is off or switch orr for at least 2 days to defrost. (insulation is very good. retry.or 2) sometimes you have an auger at top of fridge compartment. If it sticks, reduces ability to cool.Also switch off. use hairdrier to remove ice build up at auger outlet. retry. .
Sep 20, 2009 | Refrigerators
Progrmmable Thermostate
Check to make sure you have pm or am set correctly. Or reset everything. ??? ;)
Dec 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
My engine keeps blowing out the anti freeze through the fill tank overflow. I have a 2004 Super Duty 6.0 turbo.
start you truck. let the temp gage get to where it will start blowing the antifreeze out. than turn your heater on full blast. if the temp goes down and the water doesn't come out than you need to change you thermostate.
Aug 02, 2008 | 2005 Ford F 350 Super Duty
Wn`t come on
I would recommend that you contact the manufacturer as they do have a 1 year warranty. Here's a link to email them...
http://digiblue.com/customer-service/ask_us/
Mar 17, 2008 | Disney Mix Max Digital Media Player
No Picture
check the power cord
Dec 17, 2007 | Sony KV-32S42 32" TV
Sanyo Midsize Compact Refrigerator - Metallic Logo
116 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
