Question about Acer TravelMate 2300 Notebook
My acer laptop keeps comming up with a fat32 and
My acer laptop keeps comming up with a fat32 and says disc inconsistency and keeps shutting down after a while is a travelmate 4200
Alex_Woods01
  • 31 Answers
SOURCE: pls,help me !!! i have
Hi there, my name is Alex and I am here to help solve your problem
Here you will find the drivers to the VGA for both Windows XP and Vista. http://support.acer-euro.com/drivers/notebook/tm_4200.html
You will have to download the drivers first in order to install them. I hope this information helps. If you experience any problems or have any questions, please feel free to contact me.
Posted on Nov 28, 2008
SOURCE: acer travelmate 3210
yes theres a solution. go into your bios go to booting preferencess click f-9.
them press enter then press esc when it prompts you to exit saying the changes click yes.
when your sys reboots and all is well. reboot it again. second time it boots ok.
there you go.
Posted on Dec 30, 2008
dixibabe82
  • 54 Answers
SOURCE: How do I re-format Acer 4200 TravelMate hard drive?
Windows Reinstallation Disk option:
Insert Windows Reinstallation disk into tray, Boot to CD/DVD-ROM by pressing F12 at initial boot screens, delete existing Windows partition, re-create partition, and then follow steps to reinstall Windows. This will lead you to an option for formatting hard drive. I recommend choosing the full format versus the quick, from this point you can let windows install, or just shut the computer down when the format finishes. You will have to watch the progress, though, if you don't want the install to commence.
Boot disk option:
For XP, 95, 98, or ME, follow the instructions at this MS article page. It will walk you through creating a boot disk that will allow you to format.
You will need a floppy disk or CD
Posted on Apr 03, 2009
alfredo_krau
  • 62 Answers
SOURCE: how do I replace a dead cmos on acer 4520LCi
Try first to replace a CMOS battery. Normally, the CMOS do not track time when the battery is empty. And You can power on Your computer, that means CMOS is working properly and there is no reason to change it. The battery is a small piece that is placed on main board. is only one battery, looks as a slim battery for some electronic devices such a remote controllers, watches etc, so You can locate it easily. Pull off gently the old battery and replace it with the new one. You´ll see - everything will be fine and Your laptop will be an working order. I repeat, it's a common problem of the all kinds of computers, don't worry about CMOS. After the replacement probably You must to change a little bit BIOS settings, but normally the BIOS don't needs changing if You don't change it before. Sincerely.
Posted on Sep 11, 2009
  • 4090 Answers
SOURCE: cmos battery acer travelmate 4200
most times the battery is located under the ram chips
there is also 2 pins that can be shorted together that will reset the bios password if you cannot see the battery when opening the ram door.
please rate my help++++Thanks for using FIXYA
Posted on May 07, 2010
Acer desktop lost my window vista during restoration have no back up disc it keeps shutting down
What your saying is you removed your Recovery Partition? Have you tried a Full Factory Recovery? Remove ALL media DVD, CD, USB, etc. Shut down, unplug, remove battery, plug in , Power on the laptop. Immediately tap the "Alt" and "F10" keys, repeatedly.
Dec 30, 2012 | Acer Aspire 5100 Notebook
Laptop just keeps shutting down and won't turn on
it may be one of the causes, but the main reason for it is the power supply keeps on fluctuating. You may call Acer for a possible replacement for it..
Jun 19, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
Why is my acer aspire 4330 keep shutting down on me for no apparent reason?
If the laptop shuts down after a period and won't boot up again until the laptop has cooled down, then the laptop has a thermal overload problem.
For instructions to fix this problem, please click on this link :-
Normal 0 http://www.fixya.com/support/r5959377-overheating_computer
Oct 09, 2010 | Acer Aspire 5720 6497 Laptop
The notebook keeps checking the file system on C (FAT32) does that, and makes corrections and then shuts down.
Your drive has developed many bad sectors, you most likely should replace that drive with a new one. And reinstall a new operating system. You could try a re-partition and reformat this drive, but it would probably be best in the long run, to replace it.
Mar 23, 2010 | Acer TravelMate 8204WLMi Notebook
Need to reboot acer aspire without recovery disc
try in bootup using delete or F2 or F8 one of them should work for safe mode is the F8 for the mem the other two. good luck
Sep 09, 2009 | Acer Aspire 5610-4648 Notebook
Acer aspire 5050 keeps looping the acer screen and shuts down
If the hard drive tested out ok (?) then I would burn a copy of memtest (free just google it) boot from it and test the memory. I would suggest though that the issue is the hard drive or possibly motherboard
Jul 16, 2009 | Acer Aspire 5050-3242 Notebook
My acer 5100 keeps turn off i converted the system fat32 to ntfs and when it gets to the conver state where it says it will take some time it shuts down doesnt finish the job
hi
first of all check that what all services is running at the background .
you can check this by going to start >run>msconfig>click on to the services tab on bottom click on to hide all microsoft services >after doing this check that what all services are showing in the list .uncheck the unwanted files and then the system would run perfect.
if it doesnot work write an email to me with your phone number so that i can call u and can fix the computer
ullekhtandon@gmail.com
Jul 09, 2009 | Acer Aspire 5330-2339 Notebook
Acer Aspire 3610 - "C" drive full -- FAT32 error - HELP
Sounds like spyware has infected your system. Download, install, run Spybot (spybot.com) and remove problems. Good luck.
Jun 14, 2009 | Acer Aspire 3610 Notebook
Reads error fat32, and won't function once turned on and opens windows xp
If you cannot access the internet to download an antivirus program you'd have to go to a local computer store and purchase one.
May 06, 2009 | Acer Aspire 3610 Notebook
Shuts self off during start up
Sounds like there could be a major problem with the hard drive.
Have you got an XP or Vista cd? NOT a restore cd.
Mar 10, 2009 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
