York diamond 80 heater does not fire up
Have a york diamond 80 heater/AC unit. When the heater is switched on, the blower comes on at first..but the heater part that usually kicks in after a minute or so, does not come up..AC works fine. Any help is appreciated
  • 43,501 Answers
Mostly likely the problem is in the pressure switch that tells the board that the blower started and it is okay to fire the burner. The pressure switch is usually a 2" or so round thing about 1" thick, it will have one or two tubes coming out of it that go to the blower or heat exchanger. Make sure that the tube is not cracked or that it has not come off at either end.
The pressure switch can be jumped out to check out if that is the problem, but you need to jump it out after the cycle has started and the switch needs to open after a cycle for the heater to refire again, so that fix would be very temporary. But it may tell you for sure what the problem is.
Posted on Nov 14, 2009
York Diamond 80, controller is blinking Code 3 (Pressure switch stuck open).
sounds like u nee a new pressure switch. check 1\4 inch tubing going to pressure switch, remove it make sure no condesation in it., blower will only come on once flame is establised, ventor motor comes on closes pressure switch, brings on ignitor then gas the blower, make sure no blockage in vent pipe
Dec 28, 2015 | Heating & Cooling
York diamond 80 manual
where is the air filter located on a York diamond 80?
May 03, 2013 | Dayton Gas Furnace Heater
I have a york diamond 80 heater. The part that blows the heat out won't come on.. igniter lites and flames come on but blower doesn't..help we are freezing
Sounds like your fan switch is defectiveor posibble installed in the wrong place. This switch is heat controlled and delays the fan coming on until there is warm air to blow.
Dec 31, 2012 | Heating & Cooling
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
York Diamond 80 Issue. AC and Blower work fine. Heat will not come on. Circut breakers are fine, all power is on. Any advise.
Open the furnace door. Turn the thermostat on, and hold the power switch on. Look for the service code on the control board. That should tell you whats wrong with it. www.FastACservice.com
Oct 12, 2009 | Heating & Cooling
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
Heating & Cooling Logo
473 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
