Question about Garden
Gas leaks out of the carb throat/air intake opening, Carb has been rebuilt. I am thinking about the seat for the float needle valve
  • 486 Answers
Yes, I believe you are correct in your assumption. The inlet needle and/or seat need to be replaced, the part that has the rubber/viton tip. Also, make sure the atmospheric vent is open, otherwise the bowl builds up pressure and fuel will flow out of the carb floor.
Posted on Nov 14, 2009
Fuel leaking out of carburettor thru air intake valve
try screwing the bolt of the fuuel holderr in the carborator, whhichh is generally used for overflow, screw it tight ,
Apr 15, 2014 | 1996 kawasaki VN 1500 Vulcan Classic
Bribbs 550 ex carb leaks
Did you look up into the Needle valve area. I'm sure it has a seat. Usually blowing Compressed air into the Gas intake blows the seat out.
Dec 10, 2013 | Garden
My 300 utility seems to flood out everytime I try to start it. I have rebuilt the carb, including replacing the needle valve. After it turns over for 4-5 times, gas starts pouring out of the carb. I do not...
the needle is not seating with the float which is causing the carburetor to flood. either the needle is not attached to the float(some snap into a plastic groove, others have a spring) or the float is bad. Hope this helps Tim
May 29, 2011 | Desa International Garden
12hp brigg & stratton engine gas mixing with oil in engine block..when start engine runs high rpm can not idle & look like gas come out carb air cleaner overflows & flood out & stop engine...
Sounds to me like the float needle valve in the carb is leaking. This will cause fuel to over flow out of carb, and will even get into the engine oil. Check to be sure that float is not got gas in it the can go bad. Also check float adjustment. Check needle and seat very carefully for dirt or wear. Just the slightest bit of dirt or wear can cause it to leak. Hope this helps.
Sep 17, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Jet pulse carb will not feed gas to engine after start
Make sure the gaskets were installed correctly.
Oct 08, 2009 | Garden
I have fuel in crank case in 1996 road king .took off cam cap and oil and gas came out. gasket was leaking. also gas and oil coming out of carbruator.
Usually when you find gasoline in your crankcase it's because your carburator is leaking fuel into the cylinder heads. From there it goes into the cylinders on top of the pistons. Down past the rings into the crankcase. If enough gasoline goes in there, it will go past the sprocket shaft seal and into the primary case as well.
This is normally caused by a bit of trash getting under the float valve in the carburator. But, on a 1996 model, there is supposed to be a vacuum operated petcock. The petcock is supposed to close whenever there is no vacuum on it that is supplied from the intake manifold. Either the petcock has been changed, which is not unusual since the petcocks were quite troublesome, or it is not working properly.
First, you need to clean out the carb. and get any trash out from under the float valve. Remove the carb from the engine. Take the float bowl off the bottom of the carb. Pull the pin out that holds the floats and remove them and the float needle valve. Blow compressed air through the fuel inlet fitting to clean any trash out of the fuel valve seat. Inspect the needle valve for damage, replace if necessary. Reassemble and reinstall the carburator. Check for proper operation prior to starting the engine.
With the carb cleaned, you can install either an aftermarket manual petcock (Pingel) or a Harley petcock for a 1994 or prior model. These are manual petcocks. When you're not riding your bike, turn the petcock to the "OFF" position. Also, install a fuel filter in your fuel line between the tank and the carb. Get one of the good ones with the scintered metal filters in it.
Change your oil and filter. Check your primary oil as well. Change it if contaminated with gasoline. Before you reinstall your air filter, connect the fuel line to the carb and turn the gas on. Closely watch the inside of the carb throat to see if fuel starts to "bubble up" into the throat of the carb. This usually takes a few minutes so be patient. If it does, you need to replace the float valve needle with a new one and check the float setting. If it doesn't "bubble up" you're good to go. Then, don't forget to turn your petcock to the "OFF" position when you quit riding the bike.
Oct 05, 2009 | 2000 Harley Davidson FLHR-FLHRI Road king
Push mower blows gas out muffler
Your needle valve under the float jet in the carb is stuck.
You need to pull the carb apart and clean the needle valve under the float.
With it in the stuck open position, your gas will flow to the carb air intake and flow out onto the deck of the mower.
Sep 25, 2009 | Craftsman Garden
I have a sears lawnmower that was flooded recently. I bought a tune up kit and installed it. I changed the gas and oil also. when I poured in the gas it all came out the air filter. What should I check...
carburator float is stuck in the open position allowing fuel to continiously run / drain out the fuel tank into the carb and then overflow into the venturi of the carb into the engine and out the air filter. Bottom line the carb needs to be disassembled cleaned and rebuilt
Sep 20, 2009 | Craftsman Garden
Fuel problem
The float needle and seat is leaking. When the bowl is full, the needle and seat is not shutting off the flow of gas. It flow up into the carb, down the intake, past the intake valve and piston rings into the crankcase. The needle and pressed-in brass seat need to be replaced.
Jul 03, 2009 | Craftsman Garden
Gas leaking out of a 1983 cordoba top of carburetor
Did the carb kit come with a new float? It sounds like the float level is not set right, it has a hole in it or the needle is not seating right. If the float is not set correctly it will hit on the carb body before it shuts off the fuel flow with the needle and seat. If the float has a hole in it it will fill with fuel and not float at the proper angle to shut the fuel off when the desired level is reached. Remove the top of the carb and inspect the float when closed it should be just about level with the top plate from the carb. Shake the float and see if you hear any liquid in the float. Also are you running a mechanical or electric pump? Mike
P.S. I myself have forgotten to install the needle in a carb rebuild.
Let me know how you make out.
Jan 05, 2009 | 1983 Chrysler Cordoba
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
