Question about Maytag MDBH965AWS Stainless Steel Built-in Dishwasher
Mdbh965aws noise from motor
My dishwasher has a noise that appears to be coming from the motor. It sounds like grinding but is off and on, and it gets louder at time then goes away.
  • 155 Answers
Sounds like you might have broken glass or some other obstruction i your wash pump you will need to remove motor and clear before it causes to much damage to pump housing let me know how you went
Posted on Nov 14, 2009
Grinding sound in FGHD2472PF frigidaire professional
Hello friend, thank you for your inquiry!
I understand that your Frigidaire dishwasher is making a grinding noise. Typically that noise could be a faulty motor/pump. I have included a link to your manaul. If that does not help I would recommend having a technician out to your home to properly diagnose and repair your appliance. Best of luck. -Matt
Frigidaire Manual Search Results
Aug 14, 2014 | Frigidaire Professional Series 24 in....
My lgis making a horrible noise and is now shoeing an e1 code dishwasher
The LG does suffer from "poor quality" motor that causes this type of noise. The main motor and pump assembly is common to give this type of problem. The pump seal leaks a small amount of water that gets onto the front bearing and causes a "grinding = humming" noise. This can be easly replaced once you have the bottom off and dishwasher on its door. The motoe has 1 screw in the back holding the motor to the bottom and two rubber seals for the water pump in/out into the washer. Just pull and move motor and pump assmbly and it comes free. Replace with a new motor and pump assembly...
Nov 18, 2011 | LG LDF6810ST Stainless Steel Built-in...
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Dishwasher makes a grinding noise when you start it and when you open the door it appears as if the bottom arm is not spinning
    if the motor is grinding and not washing the impeller may be broken or there is an obstruction you will have to remove the motor to check this if impeller faulty purchase new part and fit good luck
    Nov 05, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
    My dishwasher has water going in to it and it drains but it's not making it to the arms, my dishes are still bone dry after all cycles even pre rinse.
    it appears ur wash motor is not running.try this-start the unit and let it run for 2 min( this is the water fill period) and after 2 mins u should hear motor running and water splashing sound.u can even open the door and look for water falling from the spray arms.but after 2 mins if u hear only a humming sound and no water splash sound then motor is bad and needs to be chgd.drain motor is seperate for draining the water.
    Aug 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
    Load grinding noise, like the engine is working too hard.
    Most likely the motor/pump assembly is worn out and grinding. If the machine is less than five years old it is under warranty. If over five years old, the repair part alone is about $150 not including labor.
    Apr 17, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
    My carlton dishwasher fill and drains but does not wash
    sounds as though the wash motor/pump is jammed or has seized therefore no wash.
    Mar 16, 2009 | Maytag 24 in. MDBH965AW Built-in...
    LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
    Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
    Hope this helps!
    Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
    Whirlpool Dishwasher suddenly making a grinding noise...
    Motors for tall tub whorlpools are over two hundred dollars. If its less than a year then its under warranty. You did not indicate model. If you can get back to me I'll look more in to seeing if it is feasable to repair or replace.
    Jul 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
    Maytag dishwasher mdb56000aww
    It seems that your motor on the dishwasher is going out, like mine has just done. My explanation is that it sounds like something is grinding on glass or as if a bunch of mice are making noise. Eventually, the motor will not run any more. What will happen is that the dishwasher will fill up, then make a loud humming noise, while the heating element is making the water near the heating element sizzle. Now what you have is a possible fire hazard which compounds the problem with the dishwasher. Get rid of it, take the loss and live like my grandmother used to, without having a dishwasher. That is the best advice I can give you.
    May 08, 2008 | Maytag 24 in. MDB5600A Jetclean II...
    Maytag MDBH965AWS Stainless Steel Built-in Dishwasher Logo
    164 people viewed this question
    Top Maytag Dishwashers Experts
    Charles T Nevin
    Charles T Nevin
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
