Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Deere 318 with Onan B43G won't start w/ starter engaged, but if the engine "catches" when I turn off igniton, it runs fine. I can only get it to start by pulsing the starter on and off--only starts when starter is not engaged. Apparently, it runs off of the magneto, but not off the battery circuit. What's wrong?
    President:
  • 1,627 Answers
318's are known to have flywheel problems and poor engagement of the starter due to incorrect alignment of the starter to the ring gear.To check either of these things you need to take the motor out of the tractor to look at the ring gear,starter drive and starter aliggnment.Before you go through this pain replace the ignition switch or have it tested.p.s deere only supplies a replacement flywheel but a ring gear can be ordered through a case dealer if you get it for a stinner with the onan engine.
Posted on Nov 14, 2009
How do you get to the starter bolts on a john deere 318 with onan B43G engine
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Apr 29, 2017 | John Deere Garden
My John Deere 420 onan stops for no reason after running for ten minutes Restarts immediatly.
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
John Deere 316 318 and 420 Lawn and Garden Tractors Service Manual
Jul 07, 2015 | John Deere Garden
My 2002 Yukon Denali XL shut down while my wife was driving it on the highway.When I reached her the truck's battery was completely dead. I purchased a new battery and now there's power but the...
Define - It attempts to turn over but won't catch and run ???? When you turn the key to start does the starter engage an spin the engine ? This would be a crank no start condition . If the starter doesn't engage an spin the engine this would be a no crank no start condition . Sorry to ask but i have only been an auto tech for thirty years an have heard a lot of different discriptions for these simple actions . crank no start or no crank no start . Very different diagnostic procedures . So when you turn the key to start , does the starter engage an spin the engine ,but won't start an run ?
Jan 27, 2018 | 2005 GMC Yukon Xl Denali
John deere 318 wiring diagram I replaced an bg 316 onan with an bg 318 onan new the starter only has one bolt for wires the old one has a bolt and a plug on where does the purple wire go on this new...
Purple wire goes to the solenoid on starter.If you installed starter with single wire post all you have to do is mount a solenoid to the frame just in front of starter,existing batt/starter cable goes to one solenoid post,purchase a short red cable and install on other solenoid post and run it to the starter,plug purple wire into new solenoid and the way you go.
Sep 28, 2009 | John Deere Garden
I have trouble starting my 316 JD tractor. When I
I do not have answer I will like to have an answer for my 316 JD no power no lights on dash battery new and was running shot off and wont stared again.Thank You
Aug 15, 2009 | John Deere New Tractor Starter w/ 317...
JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
May 18, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Starter problem
it is the cilanoid the points in side of it welded together try tapping it a few times then is that doesn't work replace it its a easy fix and is very inexpencive
Dec 05, 2008 | 1979 Ford F 350
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
537 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
