Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
We have a MF TE20, which is backfiring through carbi. Timing is checked and sits on 90, /fuel lines, filters have been checked, all ok, what are we missing? or what else can we check or do to eliminate the backfiring? Any advise is greatfully recieved
2 Suggested Answers
  • 474 Answers
SOURCE: tractor will not start ,checked timing of
ck to see if there is a tranfer pump. also ck for old fuel lines. the inside rubber may seperate and clog the line
Posted on Oct 03, 2009
When I pump the primer bulb, why doesn't it fill with fuel and stays collapsed?
new carbies start around $25.00 us on e-bay so get a new carby
take it to a mower shop for a service
rebuild the carby using a new carby kit
Nov 28, 2015 | Husqvarna 125 Bvx Leaf Blower Lawn Yard...
Not getting gass but fuel pump works & gas is clean, also it has sat inside for 12 years
Well if the pump works then follow the pump fuel lines to the engine,you will find the fuel filter then replace it and will also see petrol if any in it ,if not pump isent working ,if dirty replace it and blow air back from carby to filter to clean out pipe
,turn on ign fuel should come to filter and then with new filter in turn on fuel and see if any comes to carby if ok it should start and run.
Have a goodday,
Mar 19, 2015 | 1986 Toyota Hilux 2200
1994 5.7 chyenne sputtering problem
Check fuel filter for blockage ,check spark plugs and leads.Is it fuel injected or carby.
Aug 26, 2014 | 1994 Chevrolet C2500
I have a 92 chevy s10 4.3 fuel injected that backfires thur the thottle body. Had the timing checked, fuel pressure checked, fuel filter checked, compter and checked for leaks. Any one know what the p
Also this can be caused by defective spark plug wires as well as fuel pressure or water in the fuel. Plug wires leak more under a load as the cylinder pressure builds.
Dec 01, 2011 | 1992 Chevrolet S-10
Engine turns over strongly giving the impression it wants to go but just wont fire up. 1981 2000cc cortina
I would check the distributor cap and rotor, if any evidence of even slight corrosion
exists, this would give the exact symptoms you describe. Replace cap and rotor
and (I generally do the wires and clean the plugs as well). If this is all well and still
the problem exists then check the timing on the engine as the timing gear may have
slipped. Cylinder 1 should be at the top of the stroke when you manually rotate
the engine until the timing marks on the crank and timing chain cover align.
You can check this with a pencil or a stick to see where the highest point is after
rotating the crank if you do not have a timing light. Cylinder one is the closest
to the front of the vehicle. Use a socket and extension bar to manually rotate the
engine (in the direction it normally operates only). If ok then I would
have the ignition module tested at the parts jobber. Hope this helps.
May 08, 2011 | 1978 Ford Granada
My 1991 suzuki gsf400 has erratic idling. also is hard to start.
This could be almost anything, probably minor. Good premium unleaded fuel, fresh/clean and gapped plugs, fuel filters clean,. Carbies clean and jets good, correct float levels, no air leaks in intakes, air filter clean, Electrical connections 100%, ignition coils OK, no sign of moisture behind magneto/stator cover or on source/pick-up coils. Engine earth wire secure from head to frame?
So....
New plugs, 0.7mm gap to start with and set air* mixture screw 1.5 turns out.
To flush carby with cleaning solvent (spray can from auto access.) Take float bowls off (check for sediment) and fuel lines off and spray till it pours out of float needle seat, Loosen carby clamps and swivel carbies outwards 90 degrees and unscrew pilot jets and spray thru also. Check operation and smooth return of choke.
* Air mixture screw controls fuel-air mixture at idle speed and is a trial and error thing. Pilot and Main jets regulate cruising and acceleration mixtures and ranges according to rider style and riding and climate conditions.
If there is any undue noise comming from the top of the engine with revs slowly rising from idle to 2000 revs, you may need to check camchain tension and valve clearances, easy done with some simple tools and a manual. Downloadable free with an engine search!
Goodluck and Cheers.
May 02, 2010 | 1991 Suzuki GSF 400 Bandit
The tractor will run good and then all of a sudden it will start popping and cracking and won't hardly run at all then it will pick up speed again and run good and then go right back to popping and...
take out your air filter and blow it out and then start the tractor without it on and rev it a couple of times and then but the air filter back on and it should work i had the same problem,
Apr 01, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
It cranks but no fuel in the glass filter does this model have an electric pump? and what should i check and where on the bike it has fuel
I'm 90% sure they do. Disconect the fuel line at the carbys(ignition off). put the end of the fuel line over a container. Switch on the ignition. Fuel should now be delivered. If not you could have a fuel pump issue or a blockage somwhere between the fuel tap and the carbies. Follow the fuel lines from the fuel tank.
Also if it does have a fuel pump as I think it does you should hear it run (a buzz) when you turn the ignition on. Hope this helps Andrew Porrelli
Nov 26, 2009 | 1999 Honda GL 1500 SE Gold Wing
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
117 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
