Question about GE Hotpoint RVM1535 Microwave Oven
Microwave runs but won't heat - GE Hotpoint RVM1535 Microwave Oven
  • GE Master
  • 3,051 Answers
Hello there
here are some things to look for
If the power is on, but it does not work check to make sure the door closes and aligns properly. Microwave door switches have metal terminals on the end that make contact with the door hook or latch. This completes the circuit which allows the microwave oven to run and without this contact the microwave will not operate. A simple misalignment might be breaking the circuit causing the microwave not to operate. If you suspect that the thermal fuse has blown, call a professional appliance repair person. Even an unplugged microwave oven can kill or seriously injure someone. This is because there is a high energy capacitor inside the microwave oven case. If it is not discharged properly, you could be electrocuted.
If your microwave buzzes or hums but does not produce any heat, it could be a faulty defective diode, triode, high-voltage capacitor, or even a faulty magnetron. However, this problem usually means a bad means a bad magnetron, followed by a bad diode. Call a professional appliance repair person for assistance.
Posted on Nov 14, 2009
  • 456 Answers
Please listen when tbirdfan1 warns about the dangers of stored electricity in the microwave, But yes, the high voltage fuse, the magna trom assembly or the protective diode would be the forst things to check and replace. If you dont know how to discharge a high voltage capatitor, please seek advice of a qualified expert. Good Luck.
Posted on Nov 15, 2009
Microwave won't heat food
9 out of 10 times if all else is working then it is the magnatron rod that does the heating chances are it will be more expensive than to purchase a new microwave.
Feb 14, 2013 | Microwave Ovens
Microwave light stays on and unit won't heat/run
If it's not heating at all, the magnetron is to blame.
May 26, 2012 | GE JVM1330BW/WW Microwave Oven
Sounds like the magnetron has failed. :(
May 18, 2012 | GE Microwave Ovens
My morphy richards p80d20p-yu microwave runs normal but won't heat food
The problem is caused by a bad magnetron, inverter board, "7 years old or less" and possibily the keypad control board.
May 02, 2012 | Microwave Ovens
My Microsoft says H97 and won't start running and goes back to H97.
The "H97" error means that the microwave's inverter has shorted out and does not work any more. The microwave cannot transfer power to create heat, and the part has malfunctions and requires replacement. Use your microwave serial number and Panasonic customer service to find the proper part for the microwave.
Oct 05, 2011 | Panasonic Microwave Ovens
Microwave won't heat, timer goes off after 1 minute or so
Microwaves are a quick, convenient solution to the hassle of preparing and cooking hot dinners. They are popular appliances with students and large families where food often needs to be prepared fast. Microwaves use radio wave technology harnessed through an antenna, known as a "magnetron," to create friction between food or liquid molecules, causing them to heat up. Some microwaves can cease to function properly, resulting in the appliance running but failing to produce any heat.
  1. Magnetron
    • Magnetron tubes are often the source of heating problems in microwaves. Before having any repair work done, check the warranty on your microwave. Many companies offer 10-year warranties on magnetron tubes so you may be able to get it repaired professionally for free. Otherwise, unplug the microwave then remove the rear casing with a screwdriver. Locate the tube inside the microwave and check it for burn marks. A burnt tube cannot usually be repaired and will require replacement. A tube that doesn't appear burnt should be tested by a qualified technician to see if it can be repaired.
    High Voltage Capacitor
    • A microwave capacitor holds electricity as the appliance is running. A malfunctioning capacitor can lead to the microwave not heating, along with an irritating buzzing sound. Test the capacitor by first disconnecting the power then removing the wires attached to the capacitor. A capacitor with burn marks is usually damaged beyond repair and will require replacement. A capacitor can be tested by connecting each of the probes of an ohmmeter to the capacitor terminal. Each probe should provide a reading of infinity if the capacitor is working properly.
    Power Diode
    • The diode in a microwave oven is a one-way pathway that channels electricity from the capacitor. A malfunctioning diode can sometimes be the cause of a microwave that won't heat. The heating problem is often accompanied by a loud buzzing noise. You can test the diode by first unplugging the microwave oven, disconnecting the diode from the capacitor then measuring the level of electricity inside the diode with an ohmmeter. The ohmmeter can determine whether the electricity in the diode is flowing in one direction as it should. In most cases, the magnetron tube will have to replaced as well if the diode is damaged.
    Safety
    • Disconnecting the plug from your microwave to carry out an inspection does not guarantee safety. Even an unplugged microwave still has electricity running through its components, which can lead to severe electric shocks. Unless you have previous experience in dealing with electrical appliances, it is advisable to hire a technician to test component parts rather than undertake the job yourself. Anyone without a basic knowledge of electrical currents and safety should avoid testing components altogether.
Oct 03, 2011 | Microwave Ovens
AMANA MICROWAVE RFS-12SW2 from subway. I have 3 broken microwaves. and repair guys won't change parts to fix. so i am willing to change it myself. one of them has no heat. two of them doesn't...
AMANA MICROWAVE RFS-12SW2 from subway. I have broken microwave. and repair guys won't change parts to fix. so i am willing to change it myself. one of them has no heat.. any help and manuals? thank you
Jul 24, 2011 | Microwave Ovens
Microwave still lights up and timer still works but it won't heat anything up
The magnetron is the most likely cause, "heats food" this part is the heart of the microwave and expensive. The other two parts to consider is the high voltage capacitor and diode, but repairs will run high depending on the nature of the problem.
Jul 09, 2011 | Emerson Microwave Ovens
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My GE JVM1540 microwave appears to run but it won't heat. The lights and turntable work but it does not heat at all.
you will have to replace the microwave, sounds like a burned out magnetron, replacing the magnetron is almost as expencive as a new oven...
May 05, 2011 | GE Spacemaker JVM1540 Microwave Oven
GE Hotpoint RVM1535 Microwave Oven Logo
350 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
