Question about Olympus SP-510 UZ Digital Camera
When I use the AUTO setting picture tends to be out of focus no matter how much care I take - on other settings is usually spot on. Shouldn't AUTO cancel all previous settings? J
  • 797 Answers
Other settings can affect how it is set.
Go to the menus and find the setting for default factory settings or something like that. Set all to default.
Then test.
Posted on Nov 14, 2009
Pictures didnt develop
Hi Steph Johnson,
Numerous things could be the issue. 1, dirty lens, clean the front and back element, 2. The camera focus is not working properly not focusing on the correct spot. So, are you manual focusing or auto focusing? If it is auto then there could be an issue with that. If your are manual focusing are you sure your diopter setting is correct for your eyes, if not then it may appear correct in the viewfinder, yet be off focus.
Do you have a way to check the lens on a DSLR? If so you can try that lens on the DSLR seeing if there is an error with the lens or if it is your film camera.
Cordially
Oct 20, 2013 | Canon EOS Rebel XS 35mm SLR Camera
My picture enlargements seem to be fuzzy on the paper no matter how carefully I try to focus. Why?
It's possible you have the setting for picture quality set too low. You want to always shoot at the maximum number of megapixels your camera is capable of. Also, most cameras also allow you to set the picture quality to a setting such as fine, extra fine, etc.
Sep 27, 2011 | Cameras
With camera on the AUTO setting, I can't seem to take clear, focused photos. Nearly all of them are out of focus or blurry. Does not matter if it is in the day time or at night. Also, when using the...
Try resetting your camera back to factory defaults. Press the MENU button, select the middle tools tab and scroll down to RESET ALL. Press SET, select OK and press SET. Hope this helps.
Nov 09, 2010 | Canon PowerShot S5 IS Digital Camera
My s860 samsung will not focus the pictures are blurry how do I get it to refocus
Use the following steps one at a time and test the camera after each step. Start with a fully charged battery.
1. Make sure you do not have the focus set to "Macro", usually the graphic for Macro is a tulip symbol. Set it on Auto Focus. If that is not the problem, very carefully clean the lens.
2.Power up the camera and when the lens extends, apply a few drops of commercial lens cleaning fluid to a lens cleaning cloth or lens cleaning tissue (not a facial tissue) and gently rub the lens in a circular direction. Then with a dry lens cloth or tissue carefully dry the lens.
3. Make sure you camera's ISO setting is on Auto ISO.
4. Rest your camera to factory default by going to the Settings menu, selecting "Reset", then select "Yes" in the sub-menu.
If none of these steps work, there is damage or a defect in your camera and you must contact Samsung for repair advice.
May 18, 2010 | Samsung S860 Digital Camera
The lens will not focus automatically but will focus manually on the kodak EOS rebel XSi
Check your settings in the camera menu. Make sure that auto focus is selected. Also set the focus for OTHER than spot focus. (Spot focus can be real touchy.)
Still no autofocus? you will need service from Canon.
Apr 28, 2010 | Cameras
Washed out pictures
set auto and take pics if pics are washed out adn dis colored and streaked then
CCD failure !
call Pentax i think they will do it free of charge it is a known problem in thousands of cameras just give them a call
http://www.pentaximaging.com/support/
Mar 22, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Everything on the screen is blurred and fuzzy, the picture comes out the same
well most digital camera's tend to be sensitive for any movement during the auto focus and taking the picture .. depenidng form light (the more light the quicker the camera usually can respond) and eventually a stabelizer programme (shaking hand on a jog dial or a setup option. If the digital camera can use a macro mode check if it is off, otherwhise only the things near the lens will be good and the rest is blurry and fuzy , chaeck if the aparture can be set , for example if the lens is a 1:3.5 use a Apature 4 or 4.5 than image should be sharp , set the camera to auto mode, and believe me even the lightest movement can be fatal..
May 26, 2008 | Cameras
FOCUS PROBLEM
So... there's poor focus, and there's shutter speed.
If the light is very low, the shutter has to stay open for longer to allow enough light in to make a bright picture. Suffice to say, if you move around while the shutter is recording, it will record you moving around, and it will look blurred. That covers the concert you went to. Just use the flash. The camera will know it can use a very fast shutter speed if the flash is going to go off.
As for the person in the background thing... if they are the only blurry thing, then it's the same as above. If not, try this:
Check your camera setup menu... you should have focus options. Most toy cameras have an auto-focus that can focus on multiple points in the shot, or one point only, or even by face recognition these days! Try using a "spot focus", one focus point in the dead-centre of the shot.
On this setting, it shouldn't matter what is going on around your subject, the focus spot will be in the centre, where you are aiming it. =-]
Apr 22, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Focusing please help
I have a Sanyo VPC-S3 camera old now I know, but my main problem is with focusing, all the pictures come out very blury, you cant easily tell what the subject is.
I have tried all the setting Both Manyal, and full auto, and the focus does not seam to make any differance noi matter what I do.
Please help.
All the best.
mothergoose
Nov 06, 2007 | Sanyo Xacti DSC-S3 / VPC-S3 Digital Camera
Auto focus problems
Generally, a Nikon AF body - lens needs something of contrast to focus on (i.e., the tux of a groom) and with a white wedding dress, the autofocus tends to go 'nuts.' You could pick a spot (a pew) to focus on and then turn AF off: during the walk-down-the-asle, just shoot when the person hits that spot. In a less-than-bright church, maybe your eyes and digital are not a prime match. You could return to a film camera -- the F100 does well in lower light.
Sep 19, 2005 | Nikon D100 Digital Camera
Olympus SP-510 UZ Digital Camera Logo
114 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
