Question about Kodak EASYSHARE Z1285 Digital Camera
I cant find any batteries that will last more then ten pictures. any suggestions? so far i have used the original kodak batteries that came with the camera. kodak rechargeable Ni-MH batteries, and just plain dura-cell aa batteries. nothing will hold a charge in the camera.
  • 797 Answers
Make sure that the menu setting is correct for the type of batteries you use, this can cause the camera to calculate for wrong battery usage.
Posted on Nov 14, 2009
Which battery is better for cameras backup?
Normally, for Panasonic brand you have to use Panasonic original batteries for better backup. You have to buy newly branded batteries such as Panasonic, Kodak or Energizer in very reasonable rates. I suggest you check this link. http://www.batterywarehouse.co.uk
Apr 18, 2013 | Battery Biz Cameras
Step by Step on how to change setting's on a Kodak Easyshare Camera
You have not told us the model of the camera !!!! As far as the batteries failing that quick it is NOT a camera setting. I would suggest some higher quality batteries, Name Brand and Alkaline or better. If that does not solve your problem you have serious camera problems as no camera will kill good batteries in just a few photos.
Best Regards, Russell
Oct 31, 2012 | Kodak Cameras
My batteries drain so quickly when I put them in. I put in brand new ones and they last maybe 5 minutes. is there something i can do to change this?
hi, what battery are you using? most of the kodak digital camera using AA battery has a problem if you are not using KODAK BATTERY that specified in the battery cover. try to use duracel,energizer battery it will work after 5 to 10 shots of picture only. if you notice also the height of the said 2 battery are smaller compare to kodak batt.that's why the contact between to batt and pin inside of the camera are not good.
try to use kodak battery.
Jun 30, 2010 | Kodak EASYSHARE Z1285 Digital Camera
No power on camera Kodak C613 digital
use a rubber eraser to clean the ends of the batteries and the contacts in the camera. this will allow for more power to pass and might help. also make sure contacts are not bent down too far.
Dec 15, 2009 | Kodak EasyShare C613 Digital Camera
My Kodak EasyShare Z712 IS problem is with the batteries. I'm using the Kodak Digital Batteries and they will only last about 30 minutes..even when I just use the viewfinder instead of the LCD. My son can...
I've had the exact same problem with mine. My wife was ready to buy a new one, but I didn't want to giveup the nice optical zoom on the Z712 IS. Checking out the web and a friend of ours with the same camera, it appears to be a common problem. My last time to try the camera, I took 19 pictures on brand new batteries and they died. The Kodak site doesn't really acknowledge a problem with the camera, but I found the latest firmware (1.06) and just walked around the house taking pictures with flash. At 25 pictures, I'm still going strong. Definitely worth a try to see if it fixes your problem: http://www.kodak.com/global/mul/service/downloads/DownloadFile.jhtml?locsvcsEntryPath=10807&product=EKN033025&operatingSystem=windows_xp&lang=en&type=firmware&downloadId=dln00179_file1&variant=false&pq-path=14091
Jul 12, 2009 | Kodak EasyShare Z712 Digital Camera
Koday EasyShare Z740
I have the same problem, its as if the voltage sensor has raised it's cut off point. Originally when the batteries dropped to around 1.4v the camera would cut out, ( normal I would say ) a fresh set would sort it out. Don't use rechargeable batteries as they operate at a lower level and last a far shorter time. My problem I think is terminal and must be a fault on one of the printed circuits, so I bought the Kodak M380, not good quality pictures indoors even though 10.2 mp. Good luck.
Jun 12, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak c613 will not switch on put in new batteries had this camera since xmas
What helped my camra to get working is to make sure you have the right battery.
the kodak easyshare takes only AA/lithium,AA/ni-mi,kaa2hr,AA/zr6 and AA/lr6 and akline too. It does not work for durecell batteries.Hope I helped!
Apr 09, 2008 | Kodak EasyShare C613 Digital Camera
Battery charge
I called Kodak last night, they told me to turn the camera off, then remove the batteries and the memory card then wait ten seconds then reinstall both. Then turn the camera back on.... IT WORKED~ try it!!
Dec 01, 2007 | Kodak EasyShare CX7530 Digital Camera
Camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
Jun 14, 2007 | Kodak EasyShare C875 Digital Camera
Kodak EASYSHARE Z1285 Digital Camera Logo
115 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
