Question about Toshiba Satellite A105 Notebook
My sound is terrible. It screeches and hisses over whatever is playing.
How do I access the coin trap to see if it is clogged?
Hello. Without the model number of your washer it's difficult to make an accurate diagnosis. However, based on what you're describing, it sounds like the problem is transmission or shifter related. On most all washers, there is a rubber tub seal that the main shaft goes through and it keeps water from leaking by making a tight seal around the shaft. If this seal should leak, water with detergent can leak straight into the electric shifter(if so equipped) or the transmission causing a metal on metal grinding, scraping, screeching--whatever(you get the point). This is due to the main bearings having the special grease dissolved out of them by the detergent. The transmission could be bound up, and if the unit is belt-driven, the drive belt could be screeching due to the strain on it.
Aug 22, 2015 | Washing Machines
Screeching sound remains
Your AC pump is starting to faiL. It's starting to bind and putting heavy back pressure on the belt causing it slip and screech. After the car cools off inside, the load on the AC compressor is lower and the sound will die down. Also when the belt gets hot it gets a little more flexible and grippy which also lowers sound.
Take it to an auto AC repair place and have it checked.
Mar 15, 2017 | BMW 320D Cars & Trucks
My washer makes a terrible screeching sound when it starts agitating for the wash cycle. what could this be? it is a Hotpoint, model wlw2500b
Hi this sounds like the clutch assembly, this model is fairly old, you would probably be better off getting a new washer.
Sean
Mar 27, 2011 | Washing Machines
Screeching sound only when trying to record using LiveCam! and my
Sounds like you have another microphone connect at the same time as your camera mike and it is causing the feed back.
Or the second thing that could cause the feed back is that you have your speaker volume turned up to high.
Hope this is of some help. Bud
Sep 21, 2009 | Logitech Webcam
Dryer makes screeching noise runs for awhile then shuts off.
The 1,5 year new dryer makes a terrible screaching noise when it has a load of clothes in it. It still dries fine, no problem with the heating element. No noise without clothes, only when it has a load.
Nov 23, 2008 | Dryers
Xbox 360 disc stopped working after console moved
if the console is moved while in game play the game can become burnt. If this happens then game will become unreadable.
Nov 16, 2008 | Video Game Consoles & Games
Toshiba Satellite A105 Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
