Question about Samsung HP-S4253 Television
I have a 42" samsung tv that has 3 black line about 2 to 3 inch wide up and down across the screen.
  • 1 more comment
  • cjackson14 Nov 14, 2009
    good morning. could you give me more detail what the decoder board is. thank you
    hi. i"ve should of told you that i"ve change all the board in this tv and check all the wiring and it still has the 2 to 3" black lines from the top to bottom.and the board i use are from prefit working set,
  • cjackson14 Nov 15, 2009
    very much. thank you.
    President:
  • 1,462 Answers
Press the menu on the TV and see whether the menu is effected. If the Menu if effected, then this can be in your video cable or LCD Connector issue. but most problem is in the flex cable of LCD. some other cases cannot be fix and replace new LCD Screen
Please try the following instruction, to solve your issue:
This problem can be caused by several things,
First i suggest you to look for poor connection between LCD and ribbon wire connector that connects to the board, just press the connectors firmly and this may solve your issue, if you still have problems then i may be due to any one of the following.
-a connector on logic or address boards(in this case the lines would be localized to a half or less part of screen)
-a defective logic board that do not send the right address pulses to address board;
-a defective address board-but again it will impact only half or less of screen,
There is 60% of chance you will need a new screen. The problem you may have is dead driver (part of a screen).
There is some solution for it but not for long time. PDP panel and address driver on it not separated. If one of 26-40 drivers is going out, you need new screen.
Other common problem with lines on screen -- buffer boards , high ammount of failure for these boards due to poor electronic design ( 1-- voltage needs to operate controllers on buffer board just to high for small SMD IC ,2---they are not strong enough to drive address electrode). In future it will be changed for more reliable parts .
Please leave me comment, if you need furthur assistance
Thanks for using FxYa!
RNJ VINODKUMAR
Posted on Nov 15, 2009
  • Samsung Master
  • 3,866 Answers
This is a bad decoder board inside the tv when replaced should shore this up around $125 tops the thing is you can try to find the part here www.partstore.com I am sure you will have a good tv again once this job is done thanks and please click the accept button.
Posted on Nov 14, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Check for any high power sources near the TV or any cordless kept near the TV. These things can also affect the working of TV. Loose connection between LCD and chip inside panel or some output chips are gone bad. Also check that there is no moisture behind the lower front molding which might have corroded the small electrical connections. Don’t allow moisture to run down the screen. It may also be caused due to incorrect wiring in the TV or the wires that run to and from the TV. If still the issue persists, then this is due to a defective DMD Board or fly back transformer is bad. Please check and replace whichever is required.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
I have a Samsung 42" plasma Model HP-R4252 TV and now I see a group of blue/purple vertical lines on the right side of the screen from top to bottom. Each one is about 1mm in width but all together they...
You may have to change the DMD (Digital Micromirror Device). Also you may have to change the color wheel and lamp; the DMD will cost you around $200-$300. The color wheel and lamp will together cost you another $300.
This type of tv repair may be very expensive especially if you have to pay a technician to perform the repair for you.
It's at that point that you may decide to invest in a new unit.
Oct 13, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Black line problems
Some components in the vertical deflection amp have been going out of spec with age.
The set may no longer be worth to spend money to service it because of its age. However, if you wanted to invest the money, the set is serviceable. Considering its age, the CRT may be soft, and there are many other older components that can soon fail.
I would be considering a new set.
Jerry G.
Apr 18, 2008 | Toshiba 36A40 36" TV
Televison & Video Logo
62 people viewed this question
Henry  Thomas
Henry Thomas
