Question about Weller 8200 Soldering Gun
Cant find Tips for Weller 8200N Gun. It has two nuts that resemble cap screws only with holes in the middle that accept the leads for the tips.
    Problem Solver:
  • 12 Answers
Tips sold by Radio Shack, many hardware stores, Active Electronics in Santa Ana CA, and ebay. Cheaper to buy a card with 2 tips, no nuts. You cut the old tip, put in new tip, bend ends of new tip 90 degrees, big deal. #8125W is the best tip Weller makes for this gun, without those nuts. While you're at it, buy some "anti-seize compound" for the threads on those nuts!
Posted on May 14, 2010
  • 4,234 Answers
The tips can be purchased from MCM Electronics here:
http://www.mcmelectronics.com/product/WELLER-8125N-/8125N
Dan
Posted on Feb 11, 2010
Do stained glass soldering tips go bad or stop working. I have a weller soldering iron that doesn't heat up hot enough to solder. is it the tip or the iron
If this is the dual trigger Weller gun and your tips are held in place by either set screws or by locking nuts, Just loosen both of the parts that are holding the tip to the gun and then retighten them back up. Soldering iron tips that appear to be tight might not be and this will insure that the tip is indeed tight and also cleans up the connection of the tip to the soldering iron. Oxidation from heating and cooling will cause a tip to not get very hot. Loosen the tip holder and then retighten it. Hope this gets you going again.
Dennis
Apr 15, 2017 | Weller Welding Tools
How do you use an weller wsb25hk change tips?
Hello, just loosen the set screws on the end of the soldering gun barrels. Install new tips and tighten the set screw--sung! If your soldering iron requires that the tips have a 90 degree angle on their ends. You can bend them but be very careful because you can break them end off. The tipes are made of copper with some other alloys and the are kinda brittle. You can do. GB...stewbison
Jan 13, 2011 | Weller Standard Tip: 7200
When i put the tips in my gun it just falls out what do i need to do to fix it
There should be two nuts (ldome shaped nuts) on the end of the tubes that have the holes in them where you are installing the tips. They need to be tightened with the wrench that is supplied with the gun. Let me know if this helps. Thanks
Dec 19, 2010 | Weller 8200 Soldering Gun
Tip screws for model 8200 are worn out, What is the screw size?
The tip screws are a drilled bolt for this unit. There isn't room to tap the barrel holes out further if the threads are bad. You used to be able to buy tips that were pre-loaded with the proper clamp bolts. Good luck!
Aug 05, 2010 | Weller 8200 Soldering Gun
Need to know where I can get tips for a 8200 gun.
Sears Hardware carries Weller and and has tips for the 8200 Weller Soldering Gun, I just swa them yesterday at Sears Hardware.
May 21, 2010 | Weller 8200 Soldering Gun
The weller 8200n does notheat up
Make sure the tip is tightened fully, use a 5/16 wrench to snug it down.
Feb 28, 2010 | Weller 8200 Soldering Gun
Intermittent heat on Weller D550 although lights stay on. When not working, moving the terminals may get it to start working again. Sometimes, just moving the gun will interrupt the heat. Continuity...
Heat gun tips often get bad electrical connection where the nuts tighten to the tip ends. Remove the tip, clean the ends, re-install the tip, making sure the nuts TIGHTEN onto the tip ends. Your problem is common and always caused by a poor connection at the tip ends/nuts.
Jun 20, 2009 | RTO Weller D550 Soldering Gun
Replacing tip
i have an old 8200 and i just bend the ends of the replacement tip, then i just tighten the bolts. that is how the tip was on the when i bought the 8200. cheers
Nov 07, 2008 | Weller 8200 Soldering Gun
Weller 8200 Soldering Gun Logo
290 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Mike
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
