1998 Chevrolet Malibu Logo
Posted on Nov 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to know how much good is my gas mileage on my 1998 malibu LS
mwarej123
Level 3:
  • Master 454 Answers
  • Posted on Feb 06, 2010
mwarej123
Master
Level 3:
Answers
454
Questions
Helped
180103
Points
1400
If you want ot know what gas mileage your car is actually getting, do this.
Fill the tank all the way up. Record the mileage on the odometer. As an example, lets say it's 100,000 miles. Drive the car normally, use up most of the tank.
Fill it up all the way again. Record how much gas you needed (from the gas pump) to fill it. Record your mileage now.
Lets say mileage is now 100,500 and it took 20 gallons to fill.
That's 500 miles using 20 gallons, or 25 miles/gallon average. Do this a few times to get the best average.
Anonymous
Level 3:
  • Chevrolet Master 3,640 Answers
Anonymous
Chevrolet Master
Level 3:
Answers
3640
Questions
6
Helped
1674531
Points
10518
I have a 2000 malibu ls, and it gets about 27 in city to about 32-34 on open highway.
1998 Chevy Malibu LS anti theft fuses
First have you drained the gas tank and put in new gas.The only thing I know of is bad gas, I am thinking it is fuel injection check the fuel filter I want to help check this and I will check back tomorrow Good Luck Mike L.
How to remove a head gasket on a 1998 Chevrolet Malibu LS
-It's better for you to read in its repair manual step by step.
instead some one tell you to do on the web site or by telephone.
Good luck
Mai
I just bought a 1998 Lexus LS 400 and I put PLUS gas in the tank instead of PREMIUM will this effect my engine?
It should run ok, it might not get as good as mileage you would with premium and it might not have normal performance as with premium.
2answers
My check engine light in on. I have a 1998 chevrolet Malibu. It has been skipping and I thought that water was in gas. I have now put Lucas in gas tank.
It sounds like you may have a bad spark plug or bad spark plug wire. The first thing you need to do is find out what diagnostic trouble code is in the computer and to save money autozone will scan it for free. Send me a message and tell me what came up in the computer and we can go from there. Good luck.
I have a 1998 buick regal it has been recently tuned up was getting very good gas mileage and runnin well now it is burning more gasoline...no change in performance and no engine light codes
Good gas mileage on this car should be 19City 27Hwy. Gas mileage can be affected by many things. Assuming that the car has been recently tuned as you have indicated, I would: Check tire pressure first<-you'd be surprised what low tire pressure can do. Check for low oil level <-engine friction Cheap spark plugs. Let me know.
1helpful
Just bought a 1998 malibu the engine light came on the dealership now wants $400 to replace a valve that regulate the fule and air mixture. Can you tell me what this valve is called and does it affect...
fuel pressur regulator? egr valve is common on these as to clogging up in the passage although this is related to emissions and not so much fuel. do you have the code it set?
Droppin oil pan on 1998 malibu ls
You need to either jack the motor of loosen the crossmember.
Fuses?
the fuse box should be located under the hood, the box is labeled "FUSES"
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
