Question about SanDisk Sansa e200 MP3 Player
Sansa e200 help please
I want to erase all the songs on my sansa e200 and start over. how do i do this?
Plug it to the computer.go to start on your computer.go to my computer.you should see sansae200 or removable disk.double click there.when the window opens,erase every icon you see.any other problems, let me kow my e-mail is lilguttahakathe@yahoo.com
Posted on Jan 08, 2008
My mp3 player says that the memory is full but I have no songs
if you are deleted the song using computer interface before, it is still on hidden file. plugin your device to computer and go to your sansa directory,
unhide all hidden file and delete it if you are using windows, but for mac pc, just go to the finder then ampty the trash.
Mar 02, 2009 | SanDisk Sansa e260 MP3 Player
My Sansa e200 mp3 player has frozen and i can't add anything.
http://www.sansa.com/support/sansa_e200/faqs
First, try resetting the device as described in question 2
SOLUTION 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
SOLUTION 2 – If the problem was not resolved, download and Install the Sansa Firmware Updater.
SOLUTION 3 – If the problem was not resolved, format the device
WARNING: Formatting will DELETE all content in the player. Please backup all your data.
Please use Windows Explorer or Windows Media Player to format your device.
Dec 27, 2008 | SanDisk Sansa e200 MP3 Player
Cant switch to MSC on sansa e260
Try this instead:
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 21, 2008 | SanDisk Sansa e260 MP3 Player
you hae a croupt file
erase disk completly and reinstall your music
this appen to me all the time whn i get a bad song down load
let m know if you need any more help with this
richard from chicago
Apr 05, 2008 | SanDisk Sansa e200 MP3 Player
Problem with my sansa e200
The issue you have described with your portable device in most cases can be resolved by formatting your device. Please follow these steps even if you have already attempted them once before.
Please note that this will remove all music from your device.
Formatting the device in Windows Media Player
1. Open Windows Media Player with your MP3 player connected to the computer
2. At the top of windows Media Player select the Sync tab at the top
3. The MP3 player should be recognized on the right hand side and say "Your Player Name"
4. Above the player name is a button that says "Format Storage Media" click this button to erase all the data from the player
5. Continue with the acknowledgement of erasing all data on disk.
Jan 17, 2008 | SanDisk Sansa e200 MP3 Player
My sansa e200
-Plug in your mp3 player
-Go into 'Limewire', select a song and go 'Locate file/Open Containg Folder', you should be in your folder with all your songs. or go 'My Music' and find your music files.
-Either select all your songs, open them with 'Windows Media Player' and transfer them that way.
-Or 'Open My Computer' then open 'Sansa e200' and drag the songs from where your songs are located [My Music] to the 'Music' folder in your Sansa e200 folder.
[MyMusic] Song.mp3 >drag to> [MyComputer/Sansa] Music.
Dec 26, 2007 | SanDisk Sansa e200 MP3 Player
New songs= black screen
try to remove the battery, wait 30 seconds and replace it
this should reset your sansa,
a real hard reset isn't possible,
you can format it though
warning, this removes everything
To format your Sansa E200 series MP3 player:
1. Open "My Computer."
2. With the player plugged into the USB port, right-click on the player (if in MTP mode) or the drive letter for your player (if in MSC mode) and select "Format" from the right-click menu.
3. Press "Start."
4. You will receive a warning that the format process will erase all data on your device.
IMPORTANT: Make sure you have backed up all of your data from the device before continuing with the format. Procedure will erase everything off the player. Agree to the warning.
5. The format will complete. Close the format window and your player should be ready to use.
After the format, please install the latest firmware update for your player. Please visit the following link to download and upload the Firmware on your Sansa E200:
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00...
PLEASE NOTE: All files will be deleted. Backup your files. Your MP3 player must be in MSC mode before installing the Firmware update.
To set your player in MSC mode, please do the following:
1. When the player is turned on, press the “Menu” button.
2. Navigate to the “Settings” menu.
3. Navigate to “USB”.
4. Under the “USB” menu, go to “MSC”.
After changing the player to MSC mode, reconnect it to your computer. The screen on the MP3 player should read “USB Connected” and "MSC”
You can now complete the Firmware update download from SanDisk.com on your device.
Installation Instructions:
1. Unplug any other USB flash drives that's connected to any of your USB ports.
2. Download the firmware to your PC
3. Plug in your e200
4. Double-click on the downloaded firmware (e200fw01.00.12.exe) and follow instructions
5. Unplug your e200
6. Device will do it's own update process and will restart.
The device should be ready to be used again.
Dec 16, 2007 | Audio Players & Recorders
"unknown" songs taking up memory in my sansa e200
Renew music svc sub, convert to Mp3, or update/remove DRM licensing
Nov 25, 2007 | SanDisk Sansa e200 MP3 Player
Sansa e200 wont load music
Check if the player is in Autodetect/MTP then try retransferring the songs on the player. And before unplugging the player from the computer check if the files are transferred to the player click on the sansa e200 player on the left window to check if it had really transfferred the songs to the player. If it still wont work, try trasnferring songs using windows media player.
Jul 21, 2007 | SanDisk Sansa e200 MP3 Player
My sandisk e200 wont add songs
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 08, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
44 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
