Question about Garden
No power at all accept for power seat in back of van
No power at all accept for power seat inback of van nothing when i turn key on or no head lights or interior lights when key is off same thing either way . i dont know where to start ?
    President:
  • 1,627 Answers
Start at the battery.Make sure the cables are tight and not corroded.Check the live cable to the starter and the ground cable to the engine block.Also check the fusible links that join the positive battery power to the fuse panel for a blown link[the blown link looks like a normal piece of wire but it is made of magneizium not copper so that it will melt fast if it is shorted out].To check a fuse-link wire just tug on it ,if it is stretchy then it is blown.Good luck.
Posted on Nov 14, 2009
98 ford econoline - no power
Are you sure the battery cables are clean and tight on both ends?
You would need to use a meter or test light to follow the power from the battery to the break in the circuit.
Feb 04, 2014 | Cars & Trucks
My power seat stopped working. But the passenger seat works fine... Also it keeps telling me key not accepted but it turns on fine. Some warning light came saying brake light failure .. Please help.
At the rear electrical center, check 30A fuse 25. Replacement should get your seat moving again. The brake light warning indicator may simply mean that a brake light is burned out. I have no thoughts regarding the key problem
Oct 24, 2012 | Cars & Trucks
I have a 2011 e 350 for van when i turn the key nothing happens the battery is good so i know thats not the prob.
first check fuse box crank fuses 1 and 2 then check for loose battery conections both hot and ground if all tight turn on head lights if head lights cut on try crank see if lights dim either faulty solenoid or starter brushes if still nothing check nuetral safetey switch and pull starter to have checked
Aug 31, 2012 | Ford Vehicle Parts & Accessories
When trying to start the van, I had no panel lights. the radio works and the dome lights work. The door chime works and head lights work. but will not do anything else. Nothing lights up on speedometer...
Check under the hood and look at the fuses. The fuse box is located on the passenger side above the battery. If the fuses test good, reseat the fuses. I hope this helps.
Nov 01, 2010 | 1999 Oldsmobile Silhouette
1989 ford truck f350 diesel. head lights,hazard lights, and horn have power and work, batteries are charged but truck will not crank. when i put key in and turn the key over nothing happens....no buzzer,...
1989 f250 4x4 lighting problems. i replaced the floor mounted dimmer switch ,the lights worked fine for an hour untill i turned them off.Now the lights will not turn back on but i have park lights.
Aug 09, 2010 | 1989 Ford F 350
I have 1989 E150 van died on the way home.No power what so ever, no lights{head lights,running lights,dash light},no radio,when you turn the key nothing what so every. Thanks...
you may just have a bad alternator and the van is just running off the battery also make sure the terminals are clean and the fuselink is good give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your van wish you the very best of luck Michigan Man.
Jan 10, 2010 | 1989 Ford Econoline
No power chevy express 1500 van wont start turn the key and nothing.
Hi there, if you turn on the lights do you have head lights? if yes turn the key to start with headlights on does the lights dim? Yes? if yes that means your key is operating the starter if not it means the starter is not receiving a signal from the key to starter, need to know what it does before I go on. If no lights then the battery is dead or you have a corroded battery cable. Let me know for more information.
Aug 30, 2009 | 2000 Chevrolet Express Cargo
04' Ford FreeStar - The Radio Stay On When Van Is Off
Nothing wrong with it. When you remove the key, it stays on for about 20 minutes. It gives you time to finish listening to your radio and roll up the window. Once the driver door is open, everything shuts off or if 20 minutes has passed.
Mar 28, 2009 | 2004 Ford Freestar
Nothing when I turn the iginition switch on.
New battery 2001 chev express van 1500 turn key will not turn over.All guages work .Sounds as if starter is clicking.
Feb 01, 2009 | 2004 Honda CR-V
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
