Question about ASUS P5P43TD Pro Core 2 Quad/ Intel P43/ DDR3/ A&GbE/ ATX Motherboard
New P5P43TD PRO. Will not bootup. No diplay at
New P5P43TD PRO. Will not bootup. No display at all. No beeps. Only the hard drive lamp comes on and stays on. Swap memory etc. Put an older good PCI video card in and same result. I am guessing bad motherboard?
  • 728 Answers
Hi shipale,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck
Mark
Posted on Nov 14, 2009
I have the same motherboard and the same problem with you!
It is a new pc I purchased this week.
The parts that might have the problem are these:
(the rest are all tested on other pcs)
Motherboard: P5P43TD PRO
CPU:Core 2 Duo E8400 3GHz
Memory: G-Skill F3-12800CL9D-4GBRL
Tested with 2 working power supplies.
The PC was new, worked fine for 1 day, and the next morning I pressed the on/off button and nothing worked anymore.. The hard disk LED was on all the time, the power LED was off, the GFX card fan by a strange way worked at full speed all the time, all other fans/hard discs/dvd roms were working ok, the screen was totally blank, no posting or any messages, no beeps because the case does not have any installed and so does the motherboard.. So basically I'm stuck here and I don't have another pc with "close to" specs to test them on. Anyone else have the same problem? Any help would really be appreciated! Thanks in advance!
Posted on Nov 29, 2009
How do I make Dell 530s boot and load windows?
Are there any sets of audio 'beeps' that occur during startup? If you get anything other than a single beep during startup, it could indicate an error code for hardware failure detected during the POST phase of bootup.
If you have recovery or Windows installation CD's, try pressing F12, go to the bootup menu and try booting from the CD.
Look at the bootup menu and see if there is a hard drive as one of the options. If the hard drive is not there, or if you try to boot from the hard drive from that menu and you get error messages, that might indicate something wrong with the hard drive.
If you can boot from the CD, you may be able to use the Windows Recovery Manager to restore Windows on your hard drive, if the hard drive is working. There may also be a recovery partition on the drive that will allow you to recover Windows, but beware that files on the hard drive may be lost when you use the recovery partition.
If you have files on the hard drive you need to recover, you may be able to remove the hard drive, put it on an USB drive adapter, and use another PC to copy files off of the old drive, even if it cannot boot the old computer. After you have recovered your files, you can try the recovery partition or format the drive and use Windows install disks to restore Windows to the drive.
Apr 01, 2015 | Dell Computers & Internet
A friend is having trouble starting up her computer and she has asked you to help. When you turn the system on, the video display comes on and you hear the disk drive spinning. Several screens display and...
It could be a number of things. Most computers are programmed with sequenced beeps, ie one long beep....cmos battery low, two short beeps...hard drive error, etc. Like Mr. Hubbard requested, I will need pc manufacturer and model number to provide accurate troubleshooting information to your friend.
Sep 05, 2012 | Computers & Internet
Power port on asus p5p43td?
hi, could you write a clear question for me.
power port on asus p5p43td motherboard, what powerport? your question is not clear at all.
Feb 08, 2011 | ASUS P5P43TD Pro Core 2 Quad/ Intel P43/...
Upon bootup attempt there is no itial beep, comes up w/ hdp1password= on display and monitor displays toshiba splashscreen...?
The hard disk has a password on it. If you haven't activated yourself then it went active on its own, a sign that the disk electronic board is dying. This can't be fixed, the hard disk is practically dead so take it out of your laptop before it damages something else. Then put in a new one and reinstall Windows.
Dec 08, 2010 | Toshiba Satellite 5205-S503 Notebook
No beep codes,only flashing cursor on display. Removed ram, got beep code. Tried different processor and memory, still same, no beep, no display, no boot. Cannot access bios settings. Sounds like dead...
Sounds like a bad motherboard. To be sure, I'd remove or unplug all devices (hard drive, CD-ROM, etc) and verify. Sometimes, those devices can prevent a bootup. If you've removed all those and same thing, bad board.
May 27, 2010 | Gateway GM5442 Refurbished Intel Desktop...
Intel PENTIUM 4 865GV MOTHER BOARD doesn't give diplay
check whether with out display if any beeping sounds are coming and hard disks are running. if possible try to place a video card and then check the output.
Apr 19, 2009 | Computers & Internet
Laptop will not bootup
are there any beeps at start up
if no beep (1 short beep means sys check ok) remove and check both memory cards and hard drive and reseat them ensuring seated properly then reboot.
could be display card but sys will give 1 beep followed by 2 short beeps.
Jan 06, 2009 | Computers & Internet
Xp pro not all of my gbs
it could be multiple problems :
first your system doesnt has the software to display more gb,normally there is a software that comes with the hard drive to install it, if you dont have it, you can google the website of hard disk company for it
eg seagate maxtor have their s/w which is free downloadable
secondly your system needs to be configured to display the new drive, go to systems tool administrative tools computer management tool options and u can view the hard drive and format it or create new partitions to display it
let me know if this works
second
Jan 04, 2009 | Microsoft Windows XP Professional
I have two operating systems on my hard drive.
You can manually disconnect the IDE/SATA cable temporarily from your motherboard (the one with NT PRO & XP HOME), then you can cleanly install a Windows XP on your new Hardisk. And after installing, you can re-connect the other hardrive on your computer and format it under your NEW Windows XP, be sure to set the BIOS BOOTUP sequence that you boot on the right drive.
-mrsolution
Jun 11, 2008 | Gateway GT4022 PC Desktop
ASUS P5P43TD Pro Core 2 Quad/ Intel P43/ DDR3/ A&GbE/ ATX Motherboard Logo
812 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
