I have a toshiba external hardrive hddr320e03x
When i put movies in it i can watch them on my dvd usb i had mad a partition to divide fat 32 and ntfs and know i cant see movies from it were can i download original partiiton or files or what can i do to see movies again
  • sallar Nov 14, 2009
    usb not formating
4 Suggested Answers
WeListen2You
  • 538 Answers
SOURCE: How do I change the External HD File System From NTFS to Fat 32
back up the data
re format the drive from my computer..
then begin anew..
you know about the file size limitations of 'FAT, yes..
Posted on Oct 14, 2008
bob_computer
  • 3153 Answers
SOURCE: Iomega fat 32 formatter program does not allow me
If you really must have fat 32 (maybe for MAC use ?) then windows itself does not support doing a fat format on large drives.
However there is a fix Yup thats why they call it FIXYA
Here is a link to just what you need
Hope its what you need and good luck
Posted on Nov 20, 2009
  • 383 Answers
SOURCE: Formatting a Fantom G-Force drive from NTFS to FAT 32
my computer> right click on the terabyte> select format> make sure u change the option of ntfs to fat 32
Posted on May 27, 2010
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
Need driver for toshiba ph3200u-1e3s.
Try another computer, or get an external hard drive case, put it in, plug to USB port. You might want to check your BIOS to see if it is picking it up. If you're reading from FAT32 computer, you will not be able to view NTFS files. You can, however, convert the drive from FAT32 to NTFS, using a 3rd party program. A great one is MiniTool Partition, you don't have to lose the installed Windows, and still manipulate your Hard Drive, size-wise, convert FAT to NTFS and vice-versa
Oct 02, 2017 | Toshiba 2TB USB 3.0 External Desktop Hard...
MAC unable to read this storejet device
try the device on another Computer, if that fails then you might have a faulty device
Mar 28, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I just bought an AVEIS DH5604AL DVD player. I cant get the USB port to play.
Press the USB button on the remote and switch from disk to usb then the player will load jpeg picture or movie files from USB to play.
Dec 02, 2009 | Televison & Video
I tried plugging in my WD hard drive to my DVD player to watch movies but the player wouldn't recognize it. Thank you!
First thing is to check what format the HDD is using - if it's been formatted on a Windows box, it's likely to be NTFS - and a lot of consumer electronics devices can't read NTFS, just FAT or FAT32.
Jun 10, 2009 | Western Digital External USB 2.0 80 GB...
Phillips 1TB HDD problem, playing movies hrough DVD player (USB)
My question would be are the movies in the right format. Just because they play on your computer does not mean they will play on you DVD.NTFS or FAT 32 would have no bearing on this. They are simply data per sector protocols and are related to magnetic storage devices.You may need the proper codec for you computer so it can make a DVD you player can play.
Dec 14, 2008 | Computers & Internet
Computers & Internet Logo
241 people viewed this question
David Payne
David Payne
