Question about Asko 1385 Dishwasher
I am installing a new pump on my asko dishwasher pump but not sure which wire goes where
  • 155 Answers
There should only be two or three wires main wires brown & blue or red & black. green or green with yellow stripes is earth wire main wires connect to pump motor earth connects to earth point hope this helps
Posted on Nov 14, 2009
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
interrupted.
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Dado
Oct 06, 2015 | Asko Dishwashers
Asko model 1776 that doesn't drain. We stored it for years and have installed it without any installation guides. It was from a construction auction and it had some mice living in it in the shed. I...
Remove the drain hose and make sure its clear. Inspect the pump outlet where the hose attaches and make sure itts clear. Usually insects build nests in the end of the hoses during storage. If this is not the problem, and it does spray water during the wash cycle, it is either the separate drain pump or the control board. test the drain pump to see if it has resisitance (unplug the unit first) if not it is bad. If the pump has resistance it may be seized. Last check the control board.
Feb 12, 2010 | Asko D1776 Built-in Dishwasher
The dishwasher will not pump water in or out of the appliance.
If the appliance was recently installed, be sure the plug at the food disposer was removed. If the appliance was installed long time ago, check if glass or foreign objects are jamming the pump. If not, perhaps it needs a new drain pump.
Nov 05, 2009 | Asko 1385 Dishwasher
My Asko D1976 dishwasher is not cleaning well, andmy Asko D1796 dishwasher is not cleaning well, and there are food particles and pooled water in the bottom. How do I clean this and/or fix the problem?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
uior24567
Sep 08, 2009 | Asko D1796FI Built-in Dishwasher
New Asko Dishwasher. Both the appliance store
Make certain the door switch is making contact and the switch is good. Open the front panel and trace all the wires,especially where they go from the door to the underside of the DW. Look for a broken or pinched wire.
Jul 06, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Mar 12, 2009 | Asko D3152XLSS Stainless Steel Built-in...
New install; where to hook up old wiring/plug to ASKO
There should be an installers/repair guide folded up behind the front panel. Check for that as it will show a wireing diagram. I won't be able to get any info until Jan 2. Let me know what you find.
Jan 01, 2009 | Asko D1976 Built-in Dishwasher
Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Apr 04, 2008 | Asko Dishwashers
Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
Washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Nov 22, 2006 | Viking 24 in. Professional Series VUD040...
Asko 1385 Dishwasher Logo
233 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
