Toshiba 27AF42 27" TV Logo
Posted on Nov 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Toshiba 27AF42 and I get a high pitched squeal after the TV has been on for a few minutes. Any ideas how to fix this? Once I turn the TV and back on again the squeal goes away.
  • josephekamin Nov 14, 2009
    Where may this coil be located and what does it look like? Is is on the board on the bottom of the TV or on the board attached to the back of the tube? After I removed the case/back the TV hasn't squealed but I know once I put the case back on it will start again.
  • josephekamin Nov 18, 2009
    After over an hour of pushing on every part in the set I never did find any coil that stop squealing or that started squealing once I pushed on it. But, I must say now that I have the back off and have pushed on everything the TV now takes about an hour before it starts to squeal and once again just turning the set on and off again stops the squeal for a longer time. Any other suggestions on finding which part is my 'monster'?!?!
Anonymous
Level 2:
New Friend:
  • Expert 145 Answers
  • Posted on Nov 14, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
145
Questions
0
Helped
31648
Points
267
Yes. its the horizontal linearity coil resonating. take off back. and while unit is on, take a plastic straw and push on coils in the high voltage area. you will find one that squeals when pushed on, or will stop squealing when pushed on. solder that coil and area. that will fix 80 percent of the time. if you push on it and the squeal tone changes, solder it and silicone it done. fixed.
  • Anonymous Nov 15, 2009
    it is not the little board on the back of the picture tube. it is the big board on bottom of set. the coils will be in the area by the big transformer where the big red wire(anode lead) goes to the picture tube. just start pushing stuff around and you will find it. it might even fix it by just moving stuff.
Sony klv-32u100m: After 5-20 minutes on, there is a popping noise and then the screen goes black with a constant high pitched squeal. Audio continues to work
leave that consideration until you have taken it to a repair shop for a proper diagnosis and quote
after you get the quote and have the problem explained --then you make that decision
could save heaps of money either way
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Loud squeal when I drive.
You need new brake pads . it has a metal tip that squeals on the rotor when they are worn.
After tv is on for approx 20-30 mins it starts to make a loud high pitched squeal or whine. once turned off for approx 10-15 mins can turn it back on for another 20-30 mins before squeal will return....
Sounds like a problem I had with a Polaroid t.v. Take the cover off the back and look for capactors that are buldging on the top. The top should be slightly concave. If they are convex at all, you can buy new one at Radio Shack and replace them for under $5.00
Toshiba TV 27AF42 purchased 7-2-02 Have cable
It's not the TV. Its the remote. Remote controls don't last for ever. Try a universal remote. Try Radio Shack it should do the job. Do you have a cable converter then ask your cable comapny to give you a new remote.
2answers
Tv wont turn on and has a high pitched sound while plugged in
your flyback transformer and driver circuit are operating, but the horiz. output transistor that needs to be in circuit w/horiz output transformer is open and can't amplify the signal needed for the flyback xfmr
Toshiba Regza bought 1/28/08 makes squealing noise
It's in the repair shop. I'll write back what the problem was and how much it cost to ship.
My set has deveolped an intermittent high pitch squeal.
It always nice when the high-voltage circuit gives you fair warning of impending doom. Have the high-voltage (flyback) transformer replaced now before it fails catastrophically and wipes out other stuff with it. There are other things that could make noise too, same advice applies to them.
Hope ya fix it!
Samsung slimfit television 30"
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
