Question about HP Photosmart 2575 All-In-One InkJet Printer
Remove and check cartridge on right. Refer to Printer Documentation
  • 35 Answers
The cartridge is not installed correctly, and should snap-in-place. follow the symbols on the inside of the printer to put the cartridge in the correct orientation.
Posted on Nov 18, 2009
Cartridge error refer device documentation troubleshoot
Remove the black cartridge and keep only the color cartridge in, and check the message. Now remove teh color cartridge and insert only the black cartridge in, and check the message. This should give an idea about which cartridge has a problem.
Feb 17, 2011 | HP Officejet 5610 All-In-One InkJet...
When the printer is turned on it states: ink system failure. Unable to print. Refer to printer documentation. Error Oxc18a0001.
possible causes of this:
  • loose or improperly installed ink cartridge
  • damaged cartridge
  • dirty print head
Solutions:
  • check cartridge connection, try to remove and reconnect
  • replace damaged cartridge
  • clean printhead using the printhead cleaning utility software of your printer
Oct 21, 2010 | HP Office Equipment & Supplies
Cartridge error, refer to device documentation for troubleshoot
show me a massage Cartridge error, refer to device documentation for troubleshoot printer model hp officejet 5610 all -in- one what is the problem and how do i solve thnk you
May 22, 2009 | HP Officejet 4315 All-in-One Printer
Hpc4100 printer error message 'Remove and check cartridge on right"' Refer to printer documentation
3 causes
1 faulty cartridge
2 dirty contacts
3 print carriage ribbon damaged
Rmove cartridge and rub the golden contacts at the back of the cartridge with a slightly damp (not wet) tissue. Re insert and turn printer off and on again
If this doen't work check the white ribbon inside the printer cartridge carriage in the printer (which touches the golden contacts on the back of the cartridge when it is inserted) for damage - it might have a pinhole in it where the metal pin holding the cartridge in place has pushed back through the white ribbon
If there is no damage and rubbing the cartridge contacts has not worked then most likely it is a faulty cartridge
Let me know how you get on
Nov 11, 2008 | HP PSC 1210 All-In-One InkJet Printer
My hp photosmart 2575 says 'ink cartridge problem, remove and check cartridge on right. Refer to printer documentation
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
Aug 14, 2008 | HP Office Equipment & Supplies
HP Officejet 4355 All in One Cartridge Error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
Mar 27, 2008 | HP Officejet 4355 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
198 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
