Question about Whirlpool Duet GHW9150P Front Load Washer
My Whrilpool Duet keeps "eating socks", I have to take the cover off, unscrew the drain trap and pull out yucky, smelly socks!
    Novelist:
  • 154 Answers
That is a common problem with the Whirpool duets. Small clothing articles, especially baby socks go through the drum lip to the drain pipe.
Best to buy a zip-up laundry bag and place all the small clothing items in there.
Best Regards
Ash
Posted on Nov 14, 2009
Odors
Unfortunately this is a common issue with low water consumption front loading washers.
Fortunately there is a pretty easy fix. There are products that work great in cleaning out the hidden area that the odors come from. I have put some information on this together, follow the link below to see how to resolve, let me know if is helpful.
Smelly Washer
May 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet front loading washer with a smelly trap.
It is normal to have water in the drain lines and drain trap even when the unit is not in use. There's usually about a gallon of residual water in the lower portion of the wash tub, drain line and pump. If you are experiencing sour odors from the washer, the following link can give you some pointers on things to try to help keep the smell from coming back:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Read through the link provided and let me know if you still have problems. I personally own a front loader and have followed this regiment for 9 years now with no odor or mildew problems. I hope this helps you as well.
Jan 28, 2010 | Whirlpool Washing Machines
Where would i look for a lint trap on a whirlpool front load wash
if you remove the bottom cover you will see a round white dial..it will be full of water so beware! a gallon or more so be ready. unscrew it counterclockwise and remove filter. does it have nasty smelly lint it it? problem solved.this is all you can do so good luck! :)
Jun 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sock in lint collector slot
Take a hanger Metal one, stick it down there and twist tell you get a good grab on the sock and pull it out. The other way is to open the back up and get in there. The machine will not work at all cause it can not exhaust
Feb 09, 2009 | Kenmore 62622 Electric Dryer
Water pours out from soap/softener drawer at top...
I'm guessing, what with this having been posted nearly a year ago, that this has been resolved, one way or another, but I thought I would post this solution for the benefit of others:
We had this same problem, where water was flowing out from underneath the detergent dispenser. The problem we had was a blockage between the dispenser and the drum, so after taking the console and door-panel off the washer, I removed that black tube from the dispenser to the drum and pulled out the matted-up sock which had somehow made its way there. Good luck!
Jan 15, 2009 | Whirlpool WFW8300SW
Problem with whirlpool duet
you can access the drain pump assy by removing the 3 screws across the bottom of front panel, after that youll see the drain pump directly in front of you, youll need to unscrew t he filter cap form the "button trap"assmebly, this is what catches all the junk left in pockets, or the baby socks, so they dont make itr into the puppmp itself. be warned there will be water wanting to come out after unscrewing the cap. ALOT depending on amount of water in machine!!!!!!
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer & the clothes will not spin out the water when the washer is done they are still soaking wet?
possible that with the machine not draining, its not going to high speed spin try this:
Drain problem
you can gain acess to the pump cleanout by removing 3 torx 15 screws from along bottom of front panel. justbehind the panel youl find the "bttoun trap. unscrew it and chances are youll find baby socks, bra underwires, etc... )somethings blocking the pump from orkin proerly, be warned scoop water out first, and tip unit back if possible. when oyu unscrew the pump clean out all water above will be coming out
Mar 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET FRONTLOAD WASHER
I had similar problem, the front door seal can trap small items,socks,handtowels. I didnt figure this out for some months, each load of clothes had a foul, mildew smell, Check door seal for trapped clothes, run intermittent cycles with bleach only, no clothes, be sure to leave door open when not in use to air out , this will reduce smell.
Nov 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Error Msg F02
Hamish, that is the code for long drain. Make sure the drain hose is not kinked. Remove the bottom panel and and check the drain filter. It is right in front and just unscrews. Get a bucket handy to catch the excess water. After cleaning out the filter strainer check the impeller (hole to the right) to make sure nothing is jammed in there. Catriver...post back.
Oct 05, 2006 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
376 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
