Question about Sony KDF-E55A20 55 in. LCD Television
POWER LITE TURNS RED AND BLINKS 6 TIME IN A ROW
  • 456 Answers
I recommend that you check the power supply for any blown or faulty capacitors as well as checking all the plugs on the tv internals( all the plugs that plug into the circuit boards) Good Luck.
Posted on Nov 15, 2009
My Sony Bravia TV - Model #: kdl-52z5100 no longer powers on. There's a red light that blinks twice whenever I attempt to power it on. Please help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jul 30, 2016 | Sony KDL-52Z5100 LCD TV
KDL32EX301 6 blinks
The problem in this tv is the inverter board (ballast board)
Jun 20, 2012 | Sony KDL32EX301 32 in. HD-Ready LCD TV
Sony grand wega KDF55WF655 6 red blinks
you can try these steps if this doesn't work I suggest replacing IC8002 on the power supply
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks
Jan 24, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Disney DTD 363-Car 13" tv/dvd
I have xfinity Comcast cable connected to my Disney's CARS TV/DVD combo. I did not have a remote for it because I bought it at yard sale without it. I used Comcast's remote control. I followed their "Searching For Your Code" instructions. #1-turn on your TV. #2-hold SET till red lite blinks twice. #3- enter 9-9-1. The red lite blinks twice. #4-press nd release the CH+ key until TV turns off. #5-once it turns off press SET key nd red lite will blink twice. #6-Now u have locked in ur code. Press power and TV should turn on. Then CH+,CH-,VOL+, and VOL- should work for ur TV.
Apr 16, 2009 | Disney DTD1363-CAR 13" TV/DVD
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Sony kdf 55xs955
Low B error protect is what 6 blinks means on the LA-3 chassis
Jun 15, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Power Button Blinking Red
Talli,
The number of blinks, called error codes, is crucial in determining what's wrong with your unit.. In this case the color wheel is faulty and needs to be replaced. In that unit the color wheel assembly is Panasonic p/n# TXFEN01RP4S and is available from many sources for about $390.00 plus shipping.
There are some companies like Tri-State-Module that have taken-up rebuilding color wheel assemblies but I can't be certain that this is one of the brand/models they support. If you can have it rebuilt you might save about half the price of a new one...
For your edification in the future here are the blink codes for your Tv:
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
If I can help any other way just let me know...
Good Luck!
Bill
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Sony KDF-E55A20 55 in. LCD Television Logo
119 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
