Question about Hitachi 51F59 51" HDTV Projection Television
How do I fix my screen. The picture is too close and the ''aspect'' won't zoom it out far enough. Still can't see the words at the bottom of the screen!
  • 456 Answers
You may need to recalibrate the hdmi settings if using a dvd player, alternatively check the aspect on the tv as well as the dvd/etc input that you may also be using. Good luck.
Posted on Nov 15, 2009
Is there a way to adjust the picture size? On some channels the picture is cropped at the bottom.
this is an aspect ratio problem ans is corrected /adjusted on the on screen menu
use the remote to achieve the on screen menu and scroll around until you find aspect ratio
use the volume buttons to select and adjust
Apr 27, 2015 | Sony 40" FD Trinitron WEGA XBR Hi-Scan TV...
How do I stop the words from being cutoff on the tv screen?
You need to check the zoom or aspect ratio on your TV remote and or your cable/satellite remote. The zoom or 16:1 aspect ratio often cuts off words if the movie or show is in 4:3 ratio.
Jan 04, 2015 | Panasonic Viera TC-P50S1
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
I just bought a new insignia LCD TV and the picture does not cover the entire screen. Instead of the 32 inch. diagnal I should, I have a 24 inch picture. Is there something I can do about it?
The "picture size" on the TV needs to be set correctly. You should have a "ZOOM" button on your remote. Press it a few times, cycling through the options... see if this fixes the problem.
Be advised, many (most) HD channels do not show HD content all the time. At the broadcasters discretion, they may choose to ADD the black bars to either side (and/or top an bottom) of the image. This is what the "ZOOM" button is actually for... to allow you to correct this, filling the screen with the image.
*Note: many cable box have a "FORMAT" or "HD ZOOM" button. When used in conjunction with the TVs zoom feature, you can end up having one device set correctly, while the other is not. The result is often a picture that is expanded far beyond the bounds of the displayable area of the screen. If you can not find a solution using the "ZOOM" button, pick the setting which shows the most image. Now adjust the cable box setting (FORMAT / HD ZOOM).
Mar 06, 2011 | Insignia Televison & Video
I can't get the zoom to decrease on my tv. is it a problem with the tv, or the cable box?
This is the TV. Look for an aspect ratio or picture size or other wording button on the TV's remote control and READ your TV owner's manual. John
Jan 28, 2011 | Philips Televison & Video
Picture too large for screen
mine did not fix, picture is still huge and pushed to bottom of screen so the top is black all the way across
/uploads/images/picture-large-screen-34901330-4-1.jpg
May 27, 2010 | Westinghouse SK-32H240S Television
HD TV screen is zoomed to far out. How do
Use the Picture, Zoom, or Aspect button on the TV remote to cycle through the available screen sizes. You may also be able to set screen size in a Setup-Picture (or Video) menu.
Jan 18, 2010 | Televison & Video
My sony bravia tv's picture is so wide it cuts off certain things on the top and the bottom, like when there are words on the bottom of the screen i only see half
change picture format to 16.9 in the menu or if there is button on remote ( aspect / format or zoom ) or a picture of a square with two lines in it press until picture look ok
Dec 14, 2009 | Sony BRAVIA KDL52XBR2 Television
Picture outside of screen limits
I have Time Warner Cable and just FIXED this problem. On the cable box remote, there is a button with the word "Aspect" on it. On my particular remote, this is the "#" button (pound symbol) and by pressing that button, it gives you options of "Zoom 1", "Zoom 2", "Stretch" and "Normal". By setting it to "Normal", it completely solved the problem. Oh and by the way, my t.v. is the LG 47" flat screen LCD. Hope this helps the other frustrated folks out there.
------Dave
Jun 08, 2009 | LG 42LG50 42 in. LCD HDTV
Hitachi 51F59 51" HDTV Projection Television Logo
159 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
