Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
It wont display satellite(dish) or - Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
  • 10,865 Answers
If the satellite picture displays on other tvs in the house, and you have the satellite hooked up to the rear projection tv you may have to do the following:
1. Using the remote, select the input button. You will now see a menu of several choices.
2.Methodically go from one to the next until your satellite pix appears.
Posted on Nov 14, 2009
How do i upload the operational directions for my 500 satellite computer on my computer
Sony Satellite Dish Antenna Operating Instructions
Operating a Sony satellite dish is a process that first requires correct dish placement to ensure strong signal reception. Additionally, the satellite receiver must be installed, and only then can you use it to put the dish in operating order via the use of its signal meter screen. Fortunately, you do not need to be a professional to complete these operations properly.
  1. Initial Sony Satellite Mounting
    • Look around for a suitable mounting area for your satellite dish. This mounting area should be free of any debris and also allow for a flat mounting area. It's best to utilize a hand-held level to measure and make sure that your Sony satellite dish lies flush with the mounting surface beneath it. Also, look to the skies above before settling on a mounting area, as obstructions such as trees, power lines and tall buildings can block signal reception for your Sony satellite dish. Once a spot is chosen, go ahead and crudely aim your Sony satellite dish to the southern sector of the sky above. This will save you some time later when you return for further adjustments
Read more: Sony Satellite Dish Antenna Operating Instructions ' eHow.com http://www.ehow.com/way_6312070_sony-dish-antenna-operating-instructions.html#ixzz1NYml5eFe
May 26, 2011 | Toshiba Computers & Internet
Ive got a freesat dish and reciever but we get 90% signal but no quality any suggestions
Your on the wrong satellite, If your on any satellite youll get a high Signal but you wont get a high quality until your on the specific satellite. Astra 2A is for freesat. If you can bring that up on the menu then just keep moving the dish until the quality goes above 50% and that will suffice for a decent picture.
Mar 14, 2011 | Televison & Video
Sat finder detects signal on 61.5 Sat but receiver does not display or lock.
Hi, Mary with Dish Network Customer Service. The 61.5 Satellite carries mostly High Definition programming. If your Satellite Dish is an older model, it is not equipped to bring that Satellite in. It is the part on the Dish called the LNBF (the eyes) that will pick up the satellites. Your receiver is a Standard Definition, you should be reading the 119 & 100 Satellites. I hope this helped but if you have additional questions, please let me know.
Dec 22, 2010 | DISH Network 311 DTV Receiver
With the bell dish we have the oblong dish can get 100% signal for satelite 91 and 100% on satelite 82 but not both at the same time?
Guest 10
With multiple satellite dishes, you will get a lower signal strength on mulitple satellites as opposed to individual satellites. The reason being when pointed at one satellite, you are pointed directly at that satellite. With multiple satellites, you are pointed in the general direction of the multiple satellites so the signal will not be as strong compared to pointing directly at the individual satellite. Normally, a signal strength 50 or above is sufficient. I hope this helps.
Ray Calo
DISH Network
May 20, 2010 | DISH Network IR Remote Control
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
Pansat 2500a Dish Network Key
hola me puedes mandar las key de la pansat 2500
Feb 14, 2009 | Panasonic Televison & Video
Cannot change/move satellite
I assume this is an outdoor satellite dish system, like a c-band system? It sounds like the motor drive outside has a stripped gear on the main shaft. The motor is probably running and the sensor wheel is turning (making the unit in the house think the dish is moving) but the screw shaft is not turning.
Hope that helped
Geno
Jul 29, 2008 | Arris DSR922
Dish Network - Dish 500 Satellite 110 is not being recognized
chances are that you have only lined up the dish to pick up one satellite. there are several satellites up there for dish and its easy to miss the ones that you need. try to line up the dish keeping this in mind. if that doesn't work, write back.
Apr 30, 2008 | Televison & Video
Vs 2000 ultra wont boot
Check this link for some useful info on how to fix your receiver.
Good Luck.
Mar 17, 2008 | RCA DISH Network(r) 311 Satellite System
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
