Question about ViewSonic VA2226w 22" Widescreen LCD Monitor
My va2226 monitor will not display the red color, but the computer/video card produce red using another monitor
JMuskovitz
  • 135 Answers
SOURCE: about colors
It sounds like either an internal wire is loose, or possibly in the connector to your video cable. Make sure the connections for your video cable are tight both at the computer and at the monitor. If they are, try a different cable (cables are much cheaper than monitors, always start with the easy solutions first). If the problem is internal to the monitor, then it is up to you to decide whether to try to diagnose/fix it yourself, or buy a new monitor. The cost to pay someone else to fix it is likely more than the value of the monitor.
Posted on Feb 21, 2007
SOURCE: Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Posted on Mar 01, 2007
  • 286 Answers
SOURCE: Red color problem
Could be a bad main board or a bad LCD panel.
Make sure your cable is not causing it by wiggling it at each end.
Check that none of the capacitors on the main board or power board are bad.
Call Viewsonic and find your closest service provider. Have them check on the price of the main board. If it's under $50 it might be worth buying to see if it fixes the ptoblem.
Posted on Feb 14, 2008
  • 23 Answers
SOURCE: Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Posted on Jul 12, 2008
in9876388918
  • 170 Answers
SOURCE: Viewsonic VA1912wb is only displaying black and blue
To be sure the system is actually on press the caps lock key when on if it comes on then yr problem should be from screen display.what to do.
*disasemble the screen area then check the module,conector then the screen itself to know the actual problem. most times when u lose and tight back u find the problem solved so try it out.
if u don't get solution then call on my cell no.+919779366100.
Thanks alot,
Sanjeev Kumar
Posted on Jan 24, 2009
The monitor color is pink...i want it to change to normal color...
Colors on the monitor are produced by mixing the three "primary" colours.
If the monitor is not producing one of those three colours, you can get "pink" instead of "white".
Fix the monitor, or replace the monitor, or replace the video-card (if using a different monitor also produces "pink").
Jun 21, 2011 | Computers & Internet
Monitor turned pink
Video-cards generate "primary" colours (red, green, blue), and "mix" those colours to produce millions of "secondary" colours.
First, try replacing the "data' cable between the LCD and the video-card.
Second, if your LCD works correctly when connected to some other desktop or laptop computer, then the video-card in your computer is not working properly -- not sending one of the "primary" colours to the LCD. Replace the video-card.
Jul 17, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
My monitor resolution colour is changed to pink.
Check the data-cable between the computer and the monitor, and try a different cable.
Or, try connecting the monitor to a different computer, to see if the video-card in your computer is not working correctly.
If necessary, replace the video-card.
Colours on your monitor are produced by "mixing" the 3 "primary" colours: red/green/blue in various proportions.
Or, if part of the monitor that produces one of those 3 primary colours has stopped working, then the resulting "mix" will have too much RED/PINK. Fix/replace the monitor.
May 29, 2010 | SAMTRON 55V 15" CRT Monitor
My E771 monitor colors suddenly shifted with
Possibilities:
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
No color Red, Dell XPS 400, NVIDIA GeForce 7300 LE video card
Mike,
I would recommend for you to try different monitor, so that you can isolate the problem.
If same problem occur, try to plug in your video card into another PCI slot in your computer. Cleaning the gold fingers of the video card with a clean cotton cloth might help.
Use a blower to remove some dust on the PCI slot.
Or try inserting the video card in another computer. If you get the same problem on another computer, you need to replace the card.
Mar 07, 2010 | Nvidia GeForce 7300 LE 256MB PCI Express...
ADI GD-166G SCREEN HAS GREEN COLOUR DISPLAY
hope u r a professional..as u r handling chip-level repairing of monitor, knowing itz hazardous n dangerous..
however, check thoroughly for dry soulderings..(esp. at the crt base)..[this chance is maximum]..
see if the base is loose or faulty..
yes, it can b the 'chroma ic'..but don't ignore the associated components..(esp around the base)..
check video amplifier n sub section..
the colour diodes, transistors n resistances at the base..
for better supervision contact ur system admin/vendor....
Nov 11, 2009 | ADI Corporation MicroScan 5P (White) 17"...
Monitor colors not displaying any red only blue/yellow
update the latest driver for your video card might help.
Mar 19, 2009 | Gateway FPD1760 Monitor
Samsung samtron 55v display problem
assuming that u r a professional..
i guess there is no problem with ur monitor, it sounds like itz due to graphic adapter..either the adapter on ur system main/mother board/agp/pci/pcie is damaged or itz simply 'driver corruption'..
don't panic..check for driver update/download n reinstall graphic/display driver..
however, 1st make sure that the Screen Resolution (1024x768 or as applicable) and Color Quality (32 bit or as applicable) is correct..from Display Settings->Settings tab..
always better to contact system admin/vendor....
Dec 30, 2008 | SAMTRON 55V 15" CRT Monitor
Display does not show the color green. Green comes in as black
why not use a known good monitor
in 1 minute flat the truth.
not only that you can move or bad monitor to another pc
and see if it works.
also the cable can be bad.
Mar 13, 2017 | HP VF15 15 in.
Jul 11, 2008 | Acer X193W LCD Monitor
ViewSonic VA2226w 22" Widescreen LCD Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
