Question about Sony Ericsson W600i Cellular Phone
Phone wont power up... The red power light comes on and stays on when I plug attempt to charge my w600i.
Samsung s3 phone wont turn on only red light stays on and a buzzing noise sounds and wont turn on need help
Shut it down by holding the power button until the screen goes black, don't tap the power off button, wait for the black screen. Then let your phone charge for a few hours (maybe over night) with power off and see if that helps.
Dec 12, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
HTC wont turn on
HTCs have a known power glitch that affects many of their model of phones. Unplug the phone. Hold down volume down, volume up and power. Do not let go. Plug in power. Hold those three buttons down for NO LESS THAN three minutes. You may see a flashing red light in the process. Once you see solid red, it is in a charging state. Allow it to charge for an hour or so and then attempt to power it up normally. You may want to get a quality replacement battery from eBay or a respected vendor, since chances are you other battery is toast. Li-Ion batteries don't like to sit in a drianed state for very long without loosing their mojo.
Mar 17, 2014 | Cell Phones
Plantronics audio 995H wireless headset not charging when plugged into computer. It does not show a red light for charging. When turned on it stays blue for several seconds then flickers red for 2 or
38cafd7a-6060-4717-bc4f-b4db91cc266a.jpgI recently fixed my 955 headphones... it's probably not going to be attempted by most folks, but it saved a great set of headphones from being tossed and replaced.
Basically you need to remove the right side padding and take out the 3 screws. This gets you access to the battery. The battery is a standard 3.6V lithium battery. Pretty much the same that is in most cell phones and many small toys. You can simply replace the battery with something like:
http://dx.com/s/3.7v+li
Or... here's what I did... add a lithium USB charger to the battery.
http://dx.com/s/li+arduino
Now, if the battery dies I can plug it into USB and the phone will work while it charges.
Nov 12, 2013 | Plantronics .Audio 995 Digital Wireless...
I just got a brand new flip video mino hd and it wont turn on. i've charged it for atleast 4 hours. when it is plugged in the red light comes on. that is the only response i get from it. any...
I had to charge mine for 7 to 9 hours the first time, and make sure computer is left ON or it won't charge and the red light stays lit until it is fully charged. make sure the red light isn't blinking if it is, plug it into a different USB 2 port and don't use extension with it unless it is a powered USB extension.
Dec 28, 2010 | Pure Digital Flip Video Ultra Camcorder
When i plug my blackberry to charge a red light comes on for awhile, phone won't turn on or charge. took battery out and reinstalled but that doesnot help.
You need your charging port replaced, I could help but I'm in NY. Search Google for someone local to fix the usb port. Common problem....
Jun 12, 2010 | RIM BlackBerry BlackPearl Flip 8230 Cell...
The battery wont stay charged .when you plug it in to charge the green light comes on ,when fully charged the red light is on,when you turn it on no power
If the charger is automatically giving you a green light when you plug in the charger, the batteries are most likely damaged and will no longer take a charge. This can happen when the power chair is stored and the batteries are not charged for a while. The green light on the charger indicates the battery is full, but instead of being full of power, its full of crud. Try to replace the batteries and see if that will solve the problem.
Mar 30, 2010 | NRS Hoveround MPV 5 - Used Power...
Gets hot and won't turn on
Most of the times it's the battery, I recomend you change it, you can easily find it at RadioShack.
May 12, 2009 | Sony Ericsson W600i Cellular Phone
Screen goes blank 2 seconds after powering up and then wont work
contact your service provider for a repacement phone if you have warranty or phone insurance. its and internal problem.
Apr 26, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Buzzing Noise When trying to charge
it means your battery is too discharged to charge. when you plug the phone in, it doesn't use the AC power right away, it uses the battery to jump start it until the red lights come on the front, then it will switch to the AC power. try this. turn on the phone with out it plugged in and as soon as those front lights come on, plug the charger in. if the battery is not too discharged i.e. it didn't power down while you were talking to it, it should work. I went through three batteries until i figured it out
May 31, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Wont power on after being powered off
circuit of the fon is short or the + and - points of bettry connector are short thats why
Sep 24, 2007 | Sony Ericsson W600i Cellular Phone
Sony Ericsson W600i Cellular Phone Logo
74 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
