Question about ASUS AP1720-E1 Server
Need a replacement power supply - ASUS AP1720-E1 Server
    President:
  • 995 Answers
Go to any computer store in your place and then purchase there the power supply for your server. Tell them that you need a power supply for server type of computer. Anyway, all computer has al the same kind of powersupply. If you want, bring your server cpu to the computer store so that they will install the power supply for you. :-)
Posted on Nov 14, 2009
I have a Syntax Olevia 20HVK, we had a brown out and the tv went out. I opened the tv and found a blown fuse in the power supply, I replaced the fuse and the fuse blew again. should i just replace the...
you have shorted power transistor or mosfet on power supply that need to be replace however this need a soldering skills and electronic background if you don't have skills its better if you replace the whole power supply board.
Nov 03, 2012 | Televison & Video
NEED A NEW UNIT OF POWER SUPPLY ATX-400W REV T1
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Jan 25, 2011 | HP ATX-400W, ATX-400W Rev. T1, HP P/N:...
My printer will not turn on
First, try pressing and quickly releasing the Power button to start a Power On/Off cycle. Do not hold down the button. If this resolves the problem your done; if not continue on.
Inspect the power cord for visible damage; if damaged will need to contact HP to replace.
Disconnect the power supply (power module and cord) from the power source (wall socket) and the printer.
Test the power source, wall socket with or without your power bar or surge protector in place, with a small appliance you know works to confirm you have power. You may want to test the wall socket first and then test the power bar, etc. to make sure each component is not the problem.
If the appliance works then need to investigate the power supply. If the small appliance does not work you may need to check your electrical panel for a tripped breaker and possibly consult an electrician to check your electrical wiring.
To test the power supply plug in to the working power source; if the green light on the power supply does not light up you will need to contact HP to replace the power supply.
If the green light on the power supply lights up; reconnect to the printer.
Press and quickly release the Power button to turn the printer on. if the printer does not turn on you will need to check the USB cable.
Disconnect the USB cable from the printer.
Press the Power button to turn on the printer; if the printer turns on you will need to replace the USB cable.
If printer does not turn on, check the battery if your printer has one. A red light means the battery requires recharging; if it is still red after recharging, replace the battery.
If none of these steps resolve your issue before replacing the power supply try plugging the power supply directly in to a different working wall socket with no power bar or surge suppressor.; Press the power button.
If still no power to the printer you need to replace the power supply.
I
Dec 22, 2010 | HP Photosmart 8050 InkJet Printer
My Dell Dimension 2350 won't power on. I've checked cables, power strip, reconnected cable to a known working outlet, and looked under the hood for a breaker. Any other suggestions?
There are four diagnostic lights on the back of the unit. This linke will provide you with what they mean. http://support.dell.com/support/edocs/SYSTEMS/dim2350/advanced.htm#1218079
If all four lights are off, your power supply has most likely died (or the internal fuse is blown). It depends on how far into the computer you are willing to dive. To check the fuse, you'll need to remove the power supply and then remove the cover from the power supply. The fuse will be on the main PCB board inside the power supply. If the fuse is blown, try replacing it (it may blow again). If it blows again after replacing, then the power supply will need replacement. If the fuse is not blown, the power supply is still the likely problem and will need replacement. Be advised that Dell power supplies are special made for Dell cases, so you'll need to be sure that the replacement you get is for your computer or you will have to do some case modifications to get it to fit.
Dec 21, 2010 | Dell Computers & Internet
Wont turn on
You need to do some checks.
remove the battery and connect the ac power supply. if the laptop will switch on you have an issue with the battery and need to replace it.
If you get nothing happening wioth the battery out then it may be the power supply and again it will need replaced.
The issue may be beyond the power supply once the battery and the power pack have been replaced but can't be diagnosed unless you have a confirmed working power supply for the laptop.
Apr 01, 2010 | Dell Latitude D600 Notebook
I have an Intel D865GBF motherboard in my PC, which stopped working. I replaced the power supply because there was no power to the board. Now I have power, but when I hit the power button nothing happens.
The exact same thing happened to my D815EAA2. In my case an overheating power supply destroyed the board. Do the following:
1. Check the power supply you replaced it with works on another system.
2. If it still doesn't work with your board, the board will need to be replaced.
Nov 20, 2009 | Intel D865GBF Motherboard
What is a good replacement for the MGE 400W
all you have to do is swap it with another one with the same specs connectors and wattage, thats a good PSU, i'd replace it with 550 wats
Nov 27, 2008 | MGE 400W Power Supply (QG) Power Supply
Laptop will not power on
Shutdown the laptop
Unplug the power supply
Remove the battery
Plugin the power supply
Turn it on
If it works then the battery is shot and needs to be replaced
Still doesn't come on replace the power supply
If you replaced the power supply and it still doesn't turn on, then the you'll need to get it service as the motherboard would have to be replaced.
Jul 23, 2008 | HP Pavilion zd8000 Notebook
Power supply replacment
You should be able to replace the power supply. It is usually held in place by 4-6 screws. Unplug the cables on the motherboard and drives. Reconnect the new ones and away you go. A generic supply will be fine if it is of the correct physical size. Bring the old one with you when you go to get the new one.
Dan
Mar 18, 2008 | HP Pavilion A520n (DW233A#ABA) PC Desktop
ASUS AP1720-E1 Server Logo
74 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
