Question about Samsung Exclaim M550 Cell Phone
I have the new exclaim and the GPS was working fine for me untill today...now when i try to access the GPS it tells me that there is not enough file space to run this application. please some files and try again.....the thing is is that I have deleated games and pics to get more memory available but it just keeps telling me the same thing...help
  • HTCphanatic May 11, 2010
    Did you turn the phone off and back on?
TomTom Go730 worked great yesterday, is a brick today. Battery charged, reset per TT website instructions, nothing. Any suggestions?
not much to do with that unit, check with a volt meter to verify that power is present at the plug cord charging, if all your efforts fail and the unit is dead your trouble is in the unit itself, this unit is not serviceable by any one other than one with knowledge and equipment to repair this unit, check for warranty if not obtain a new one,,,?Sorry
May 18, 2012 | Tomtom GO 730 Car GPS Receiver
Navman MY75T was working fine for several weeks, but today it won't start up. Tried to reset several times, but no luck. It gets to the Safety Agreement screen, and when I press the "Accept"...
1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
Nov 02, 2010 | GPS
My Xog GPS will not hold a charge. With low batt it keeps turning on then shutting off --- until the batt is totally dead what do i do
Get a new battery at Batteries Plus. Take the GPS in and they have to switch the connecter end from the old battery with the one on the new battery (part # PDA-192LI) and put the unit back together and everything will work fine. I just did it today. The cost was $25.19 :)
Aug 12, 2010 | Lowrance XOG GPS Receiver
I got the VR3 gps with back-up camera less than a month ago, the first day it worked perfectly fine, then when I installed the route 66 stuff it started showing me some really long message saying to...
Ok so this happened to my gps after an improper shut down. Here is how I fixed it. Follow each step carefully and make sure your gps is fully charged before beginning.
1st open up the route 66 disk to see files not actually accessing the program. Right click on the disk and tell it to open from my computer. you will see many files one folder will say memoryimage.
2 Then on the gps click on settings and go to backlight setting backlight to the dimmest stetting. Now go into power and tell your gps to never standby.
3 Plug your gps into your computer then turn it on. Windows mobile will come up click on connect without setting up your device. Under file management click on browse contents of your device. You will now see what is actually on your gps. Open NANDFlash.
4 Now select all items except the route66 folder in the memoryimage folder of the disk and move them into the NANDFlash folder of your gps. When it asks how to transfer tell it to replace current folders with the same name. It will then take several hours to transfer.
5 On mine the route 66 exe file would not transfer back into the actual route 66 folder so I created a new folder then transferred the route 66 exe file from the route 66 folder in memoryimage of the disk into my new folder in NANDFlash. Once it is transferred you should be able to click navigation on the gps and have your gps load route 66. Your maps will be locked.
6. I kind of forgot how I did the next step because I cannot get back to where I was because I have already activated my gps. Go into the main menu from inside route 66 and either enter the extras folder or route 66 settings. Somewhere in one of these you will find a place to activate your route 66. It will then give you a website and an id for your gps. Go to the website and enter your gps id and the code from the voucher code card which came with your gps. Once entered on the website you will receive an activation code which you will have to enter into your gps. I recommend you turn off your gps then turn it back on and give it time to find you. You can go into gps status to watch for a signal and once you have a good signal it may take several minutes to locate you. After it has found you it should be working fine.
Aug 06, 2010 | GPS
Magellan Roadmate 760
The weakness of the 760 is the cradle. Is the power wire or the cradle loose or wiggles? You may need to buy a new cradle if that is the case. They are expensive. I soldered my power wire right into the cradle and it worked fine.
Aug 26, 2008 | Magellan Roadmate 760 GPS Receiver
IO Device Error
My Maxtor died like this. The disk was OK, it was the electronics that blew. I bought a new empty disk drive box and fitted the disk drive and fixed it. Years later the disk still works in the replacement box and power supply. I got my files and data back with the disk drive in the new box. The size of that disk looks small today. It may be Parallel (PATA) and you need a PATA box, that is harder to find as obsolete. You need to try the disk first in another drive holder.
So PATA and SATA??? Look here and read up about it with pictures too:
https://askleo.com/whats_the_difference_between_sata_and_pata_and_ide/
An external disk unit has three main parts.
1. The disk drive.
2. The electronics box.
3. The power supply.
Sep 08, 2017 | Maxtor One Touch (RBAY080B0USR) Hard Drive
Whistler WGPX-550 file missing error
There is a patch for this on Whistler's website - go to their FAQ page for WGPX and look for the intellinavEN problem
Apr 17, 2008 | Whistler WGPX-550 GPS Receiver
Garmin etrex legend
I had this problem today, updated the software, now the unit seems to be working perfectly. The unit "crashes" (single line down screen center) as soon as it get enough satelites to work with WAAS.
Go to Garmin site for software updates. Download and install the WebUpdater. Once or unit is hooked up to your computer and you have internet access, the software will download and update your GPS with the latest software fixes. I had software Version 3.7. For the Legend, Version 3.9 fixes the problems with WAAS.
Jan 04, 2008 | Garmin eTrex Legend GPS Receiver
Samsung Exclaim M550 Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
