Question about LG enV3 VX9200 Cell Phone
Can't get or make calls. Timer is on.
Help..somehow I've pushed a button or something, but when I dial a call or when a call comes in, there's this timer icon that goes on and I can't hear the caller and they can't hear me.I can't figure out how to turn it off!
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 | Watches
I have an Intermatic 24hr. Dial Time Switch box (mod.T104R) that is connected to my in-ground spa by a pneumatic with a rubber push button located on the spa deck. I pushed the button a couple of days ago...
You have 240Volt T104 Intermatic timer.
The clock works, and the spa works so voltage to the timer and spa are good.
You have push button control located on spa, and it stopped working.
1) The push button does NOT control the timer. T104 is mechanical timer, and the push button cannot activate the switch contacts, and there is no solenoid inside the timer that gives that option.
The push button is a separate problem from the timer.
So replace the push button.
Example push buttons at Grainger:
http://www.grainger.com/Grainger/wwg/search.shtml?op=search&N=10866&in_dim_search=1
2) Timer problem.
What does the timer do?
If you have a push button, why do you need the timer?
T104 is mechanical single-channel non-electronic timer, and cannot override the push button once the push button is OFF. They make industrial timers that can perform multiple functions, but T104 is not in that category.
This makes me think the timer dial does not have trippers mounted on the dial, or the trippers are worn down.
Maybe the timer function is by-passed. Maybe all wires are on terminals 1 and 2.
Check how the timer is wired, and then add a comment.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Aug 24, 2011 | Intermatic T104 24h 208-277v Mechanical...
I can't seem to get my outdoor Intermatic 7 day 7night timer to work. I've had it a couple of years and use it to turn on and off a water fountain. Hwlp!!
Timer is not identified
Some Intermatic outdoor timers have a battery located in back of timer.
Some have no battery.
Some timers are hardwired, and some are plug-in.
Some are 240V and can stop working if breaker trips off on one leg.
Check that timer has power. If timer plugs in, then try timer on another load and another outlet.
Some timers have trippers and dials, and others are programmable.
Some have no repair parts, others have repair parts.
If timer is programmable, then some have a reset button you can push and possibly restore functionality. Other timers are reset when you remove battery.
1) Add a comment and say what timer you have with description of dial or description of timer buttons. Be sure to open links below to help identify timer.
2) Also include in-focus photo of timer that you posted on Flickr for possible identification, and more help. Some timers have been discontinued, while others are replaced with same model.
3) Open following links to identify timer and/or troubleshoot timer problem, depending on what timer you have.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Hardware & Accessories
How to set time
You posted under Intermatic TN11C timer.
If you have a different timer, then add a comment and describe timer, or add a comment and include photo of your product for best answer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
TN timer comes with red and turquoise trippers
Red OFF tripper #107TN222
Turquoise ON tripper # 107TN221
Place trippers around outer edge of dial at on-off times you select.
Turn lamp ON, plug lamp into timer, plug timer into wall.
Manually rotate dial clockwise to watch lamp turn on-off.
Move switch on top of timer both directions to see how to set switch.
After setting switch and trippers, manually rotate clock dial until current time line up with arrowhead located on inner dial.
Dial rotates as time passes, and trippers push switch that turns lamp on-off
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 13, 2011 | Intermatic TN111C Standard Lamp &...
I just bought a GE 24 hour mechanical time # 15152. How do set it? The dial is very confusing. I understand that I must first pull all the buttons up and push down the ones I need. If I set it to go...
GE 15152
http://waterheatertimer.org/GE-timers-and-manuals.html#15152
Light side of dial is am hours
Dark side is pm hours
Set timer ON from 5pm to 11 pm:
When segments are down, timer is ON.
Lift all segments, except segments between 5 and 11.
Rotate dial until current time lines up with arrowhead located on inner dial.
Move switch to TIMER ON
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 16, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
We have a timer in our switch panel and lost the instructions how to set it. It has a knob with the time on it (day and night). You can push it to turn it on. How do we set it to come on automatically?
You can see several types of timers here to identify your make and model
http://waterheatertimer.org/Programmable.html
If timer does not rotate around on its own, then it might not be working as a timer any more, but the manual override still works as on-off button.
Usually dial timers have tiny pins that move up and down. Look closely at the dial, and then experiment by pushing all the pins one direction.
Below the dial on newer timers is a selector button. On-Auto-Off or On-Off-Timer. To operate timer, set selector to Auto or Timer.
Sep 28, 2010 | Hardware & Accessories
The soap dispenser does not spring open automatocally
depending on the style of dishwasher- wether it has a dial or push buttons-- there is a arm that comes of the timer on the dial style that somtimes comes disconnected inside of the door or breaks.. if it is a push button controlled it may be the solinod to pop the door open.
Nov 11, 2009 | Dishwashers
AVAYA 5610SW IP Phone will not ring, only red light come on
Under the options button. There should be an "Audible alert" option...
Apr 02, 2009 | Avaya 5610 IP Phone
LG enV3 VX9200 Cell Phone Logo
105 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
